It is currently Fri Apr 26, 2024 1:31 pm
 Post subject: 180 Durability
PostPosted: Sat Feb 03, 2018 9:30 am
Hi,
Thanks for your time and expertise. Researching purchasing a 2018 Revo to replace older Revo. Interested in the upgraded seat and 180 drive. Read on another forum that some prefer the older “ bullet proof” drive. Just want to double check and ask is the 180 just as “bulletproof” as the older drive on my circa 2013 Revo?
 Post subject: Re: 180 Durability
PostPosted: Sun Feb 04, 2018 3:31 am
Its in version 2 phase to iron out some weakness in first release...I am sure it will keep being improved as anything that can go wrong will go wrong
PostPosted: Mon Feb 05, 2018 10:50 am
So long as you're not running into obstacles with the fins vertical or constantly dragging the fins over oyster beds, etc., they're darn tough.
We always recommend Hobie Multi-Lube for servicing the drive:
Hobie part #: 5120 HOBIE MULTI LUBE 1 OZ
Hobie part #: 5121 HOBIE MULTI LUBE 4 OZ
Here's two links that should be helpful as a general maintenance guide for keeping your Mirage Drive functioning at it's best.
Lubrication points: https://www.hobie.com/forums/viewtopic.php?f=60&t=12576
Inspection and Adjustment: https://www.hobie.com/forums/viewtopic.php?f=60&t=12578
Howie Strech
Parts & Accessories Product Manager
