It is currently Sat May 04, 2024 5:22 pm
 Post subject: Bottom job advise needed
PostPosted: Mon Mar 19, 2012 8:51 am
Bottom job advice needed.
I bought yesterday 1994 Miracle. Upon inspection I found:
1. bottom of the hulls stripped off gel coat at about 1” wide
2. crack about 2”-3” long on stripped bottom of port full
3. edges of daggerboard’s wells chipped a bit
Previous owner claims hulls not collect any water.
Should I put layer of fiberglass on stripped area and then apply gel coat on top of it? Should I open crack and fill it up with resin? What to use to fill chipped spots? Should I use polyester or epoxy resin?
Andrew
A lot of great surfers were ruined by family and steady job.
PostPosted: Wed Mar 21, 2012 6:58 pm
Probably don't need to add glass to that - it's just the gel coat worn off from dragging it on the beach. I'm assuming the "bare strip" extends aft from the centerboard trunk. A picture would help.
motogon wrote:
2. crack about 2”-3” long on stripped bottom of port hull
Where exactly is the crack? Is is extending aft from the CB trunk? A picture would help here, too.
Edge of the wells, or the daggerboards?
Use polyester resin for repairs. It's what the boat is made of. Only use epoxy when obtaining good adhesion is a problem or where you absolutely need the extra strength. Polyester does not stick well to epoxy (don't try spraying gel coat over epoxy). For filling dings and fairing, Evercoat Formula 27 is a good, general purpose, polyester filling compound.
PostPosted: Thu Mar 22, 2012 3:29 am
Here is pictures
crack around 3" long
scuffs
Andrew
PostPosted: Thu Mar 22, 2012 5:45 pm
BS!
You should be able to do a proper repair then gel coat. Do you have cradles on your trailer? It looks like the boat has been resting on a roller and that is what caused the crack. The H20 needs cradles or a full bunk to trailer.
PostPosted: Thu Mar 22, 2012 5:49 pm
hobieandy wrote:
BS!
Agreed. That crack needs to be glassed for sure. And don't drag a 20 around. They need to be moved on wheels. That boat has clearly been dragged around a lot.
PostPosted: Fri Mar 23, 2012 7:07 am
The dings around the daggerboad trunk can be filled with Formula 27, although the one with the deep hole looks a bit suspicious. I'd grind that out a bit with a Dremel tool to make sure all the damaged bits are out. Then I'd mix up some chopped glass with some resin to make a more robust repair.
That crack is a big deal.
This is the area that needs to be removed (minimum):
That lighter colored area inside the ellipse is delamination and needs to be ground away. Get out the disc grinder and go to work. You might find other delam under those black scuff marks. It really looks like the boat was put on rollers, which can cause this. Don't ever put a 20 on rollers! Cradles only!
You'll want to use the repair techniques described in the "This Old Hobie - Blind Hole Repair" from the May/June 2008 HOTLINE - http://www.w1dm.com/projects/HOTLINE/08-05-06%20HOTLINE.pdf
This boat looks like it was dragged over rocks.
