It is currently Sat Apr 27, 2024 5:29 pm
 Post subject: Shroud Extender
PostPosted: Mon May 07, 2018 8:19 pm
My H21SC came with these shroud extenders https://www.strictlysailinc.com/product/hobie-cat-17-solo-upright-system-part-1263-copy/. It looks like the mast ends up being supported by the quick release pin. My question for all is.. is this safe? Are these Quick release pins designed to bear the weight of the mast?
 Post subject: Re: Shroud Extender
PostPosted: Tue May 08, 2018 9:45 am
The boats came from the factory with shroud extenders. I am not sure about the specifics on the strictly sail ones, but the hobie ones work great. It would be quite the challenge to right the 21SC without the extenders.
So while I can't answer your strength question, I can tell you that you are really going to want some kind of shroud extender.
PostPosted: Tue May 08, 2018 10:25 am
Don't know the manufacturer of the pins. But you can look up similar items on line to get a good guess as to the breaking strength and tensile strength. Double shear load from one such is 9200 (they don't say whether Kg or Lb). http://aircraftproducts.wicksaircraft.c ... elease-pin
Conservatively, you would want the part to be able to lift the weight of the boat before breaking. Hobie is not known for under engineering rigging; so I wouldn't worry.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Tue May 08, 2018 2:04 pm
I have used the Johnson Hyfield type lever for my shroud extenders on my 21SE since it was new in'89. The quick pins have never fail. :D
Bill 404 21SE
PostPosted: Tue May 08, 2018 8:36 pm
Well I'm pretty sure that the ones on my boat where manufactured by Hobie. The link I posted was just for reference.
PostPosted: Thu May 10, 2018 9:37 pm
My bigger concern with quick pins is the pin falling out, not that it would shearing off. The hole it goes in could get deformed a little allowing th little ball to not keep the pin captive, or the ball could get stuck in the quick pin allowing the pin to fall out. Just my 2 cents.
Scott
Hobie 18 w/wings
Hobie/Holder 12 Funseeker
2 Hobie Waves
Tandem Oasis Kayak
Hobie 16
Southern California
