I acquired an iTrek9 in July and enjoy its lightness and maneuverability. I recently flew with it from NYC to Miami with no issues. However, over time it has developed a slow leak. Because down here I am right by the water, I tend to leave it inflated overnight so I can head right out in the morning. But when I pump it up to 9lbs psi in the afternoon, by the next morning it is down to about 5lbs and later that day down to 3lbs. I spent 90 minutes using soapy water to find a leak, but could not. Then I brought it to my local Hobie dealer, and they also could not find a leak, so I am stumped. I also own an i11s, but that yak holds air much better. Maybe loses .5 lb/day. Does anyone else here have this problem or should I assume the iTrek 9 has some overall porosity that allows the air to escape w/o making soap bubbles? Is this a design flaw in the new lightweight skin? Given this yak has only one chamber, I do not want any surprises! By the way, I store it in the shade so it does not overpressurized.
Hoping Hobie or someone reading this will have some insight
