It is currently Thu May 09, 2024 6:06 am
PostPosted: Sun Jul 02, 2023 6:11 am
I've created an easy to use, super-fast bilge pump installation kit compatible with Hobie 8" Twist & Seal hatches. You can install a bilge pump and float switch in minutes without drilling holes and without using any glue or adhesives. With my mount, you can easily move the bilge pump to a different hatch or a different boat in minutes. The kit is designed to be used with specific bilge pumps and float switches so check with me before ordering your pump and switch. A detailed, simple to follow installation guide is included, along with a suggested materials list for additional materials you might need, like a discharge hose, thru-hull, battery, etc. The kit sells for $85 plus shipping, payable by PayPal or Venmo. We will work together to select a shipping option that meets your needs before payment. You can contact me at [email protected] or 719-499-0647. Thanks.
Tom
PostPosted: Sun Jul 02, 2023 11:06 am
Not sure you will get much interest without a photo and more details (like is hatch and space beneath still usable, does it require a set distance or range between hatch and bottom...). Since it requires a specific float and pump, suggest your kit include those items as well as the other bits you noted. This "kit" seems to requires a lot of additional parts making it hard to understand what it actually contains.
Peter
