narwhal wrote:
Thanks Crazy - that is very helpful!
After you take the T Handle off tie a light cord To this before letting it go back into the
Hull.
Then you can pull it back through after you have got rid of or modified the bungy section.
There is a plastic piece that is pressed into the hull that this line goes through it you pull this out
First it creates a larger hole in the hull to pull the line through.
You only need enough slack in the system to access the rear of the bungy
From the rear hatch,
I don't know how much you would need to release.
In mine the line had broken so I pulled it all out to see what happened but you really only need to get enough
Slack to get at the rear section ,
Hope this helps , but as I previously said there's probably an easier way to to this that someone else
Can suggest.
(I have only had my ai a short time so I don't know )
