It is currently Fri May 10, 2024 3:30 am
PostPosted: Wed Oct 13, 2021 4:35 am
I understand how to run the new rudder up-line thru the hull but how does one tie off the end right at the rudder--do you have to take out that little metal pin? why is it such a tight fit there for that knot??
PostPosted: Fri Nov 05, 2021 5:14 pm
I did take out the metal pin, pushed it out with a screw. then push the line far inside the rudder where it should be , then reinstaled the pin and did the knot
