It is currently Sun Apr 28, 2024 5:10 pm
PostPosted: Mon Apr 30, 2012 6:51 pm
Thinking about converting from stock 2:1 main sheet to 3:1...Any pros and cons on this? What is the length of sheet needed for a 3:1?
PostPosted: Tue May 01, 2012 2:16 pm
Hobie Tech / Moderator
The only con I know of is that it limits you to one seat that can control the main sheet. It will make it easier to pull the sail in with 3:1 vs 2:1. You use the same line that you use for 2:1.
Brendan Castile
PostPosted: Tue May 01, 2012 2:25 pm
i switched to 3:1 when i realized my girlfriend didn't have the strength to pull the sheet in, so why did she need control? on windy days it's very nice, easier to control and fine tune the sail.
the TI3 rear ama mod
PostPosted: Tue May 01, 2012 5:18 pm
The only con I've found is a LOT more sheet line in the hull.
