It is currently Fri Apr 26, 2024 6:22 pm
PostPosted: Thu Mar 29, 2018 6:12 pm
Both sides have same appearance.
PostPosted: Thu Mar 29, 2018 7:44 pm
All the boats are that way, the strut is bolted directly to the brass insert, (they need to remove the plastic so the strut bolts directly to the brass inmold insert), otherwise the plastic would just ooze out when they tighten the bolts.
FE
PostPosted: Fri Mar 30, 2018 2:48 am
Thank you FE.
