It is currently Mon May 06, 2024 5:23 pm
PostPosted: Sat May 01, 2021 9:20 am
I'm replacing a damaged furler drum. The mast is Fiberglass and I'm assuming the furler drum is HDPE. What adhesive should be used to make this bond between the furler drum and the mast?
PostPosted: Mon May 03, 2021 4:51 pm
Epoxy.
PostPosted: Mon May 03, 2021 8:24 pm
There are many different types of epoxies. Certainly ones that don't adhere to HDPE. Can you elaborate on what Epoxy would be considered ideal for adhesion between the Fiberglass and HDPE. Is there a manufacturer's recommended epoxy?
Thank you,
Eric
PostPosted: Tue May 04, 2021 9:42 am
The drum is glass-filled nylon. We would be using something like West System G Flex.
https://www.westsystem.com/specialty-epoxies/gflex-650-toughened-epoxy/
PostPosted: Tue May 04, 2021 7:11 pm
Thank you Matt!
