It is currently Mon May 06, 2024 7:30 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jul 19, 2018 8:56 pm
Starting the rebuild of these drives.
Also, this is interesting:
[youtube]https://www.youtube.com/watch?v=Jfi6SLQ_Ju0&t=[/youtube]
^Not sure why the youtube tags aren't working, just copy paste the UrL...it's worth the look.
Thank you,
Roy Niswanger
PostPosted: Fri Jul 20, 2018 3:57 am
Here is your video
https://youtu.be/Jfi6SLQ_Ju0
If you load the video in youtube then click share, then paste the last part ( Jfi6SLQ_Ju0) in between the youtube2 quotes,
PostPosted: Tue Jul 24, 2018 10:52 am
Roadrunner wrote:
Save yourself some money by straightening your existing masts. You don't even have to detach them. I use a 3/8" ID pipe with a sleeve, but most people just do it by hand.
Roadrunner, can you help with the tube dimensions, the ID/OD of the brass sleeve insert one and ID/OD of the SS outer tube? Where you bought/found them?
Thank you,
Roy Niswanger
PostPosted: Tue Jul 24, 2018 8:28 pm
This is simply 3/8" ID galvanized (not SS) steel pipe I picked up from a scrap metal yard in town. The brass is 9/16 ID thinwall tubing that I found in a hobby shop. If you don't have the pipe, you don't need the tubing. But if you do, take it along with a mast and make sure it fits right. As I mentioned before, most people just use their hand, and that's exactly what I did before finding the pipe. The masts have a tendency to bend where they previously bent. It doesn't have to be exact to work. In fact, several users have slightly bent fins and don't even notice. 8)
