It is currently Mon May 06, 2024 6:32 pm
PostPosted: Wed Mar 16, 2022 1:11 pm
New 22' PA14, never seen the water yet and the skeg line has already worn a groove in the hull. Looks as though there was some sort of grommet there, If not there should be.
I can't be the only with this issue and I'm hoping I can get some sort of fix I can do to sure up the string grove and stop the wear from happening in the first place.
Dealer is over 3 hours away and if it's a fix I can handle I'd rather do that.
fixing image link
PostPosted: Thu Mar 17, 2022 10:40 am
That's completely normal. Send it!
PostPosted: Fri Mar 18, 2022 10:23 am
okay thank you for the quick response...Concider it sent :D
PostPosted: Mon Mar 21, 2022 11:26 am
It’s completely normal for a rope to wear a groove in the yak? Are you sure this is normal? Doesn’t seem right on a $5000 yak
PostPosted: Mon Mar 21, 2022 2:09 pm
I too would be rather concerned if that was happening in my boat. Poor design, needs something done to prevent that.
2014 Hobie Outback set up for rod and longline fishing
PostPosted: Thu Mar 24, 2022 4:38 pm
The line smooths the path and it has not been a concern or a warranty problem I am told. There are tons of examples of moving parts that break-in on all products... or wear slightly when used.
PostPosted: Mon Mar 28, 2022 12:29 pm
Just looked at mine and it’s missing the grommet going into the hull so a groove formed there too. In my case though it’s keeping the skeg from dropping all the way. Was wondering why the skeg didn’t seem to help.
Is there a part# for the grommet? Can it be also added to the hole for the line going down to the skeg?
PostPosted: Tue Mar 29, 2022 11:00 am
There is no grommet added here as I understand it. If the line is now restricted, get a photo to your dealer to file a claim... it can be chased by our warranty team. If documented damage is occurring, they could then ask engineering for a change or update. But based on previous comments by our tech/warranty manager... he is not seeing this. Documentation will help.
PostPosted: Thu May 12, 2022 2:34 pm
Just an update to this. It's been about two months of heavy use(~3 times a week for 4 to 8 hrs each) and besides the initial wear in groove being established it has not seen any more wear.
