It is currently Fri Apr 26, 2024 3:12 pm
PostPosted: Mon Aug 07, 2006 4:07 pm
I bought the hobie adventure from Kiyo who won it at the kayaksportfishing tournament this year. It came with the internal kaya bait tank. I have noticed the kayak has had alot of water in it when I return from a day of fishing. Did a close inspection and found a small hole in the plastic just under where the front part of the pedal drive goes. Can this be fixed? What should I do?
Also am having trouble with the rudder, does not want to go up or down with out help. Have to pull the handle up half way and pull the rudder up by hand and then put the handle down to lock it in place.
The hobie adventure is a great boat. Just need help fixing a couple of problems.
Thanks, Aaron
PostPosted: Mon Aug 07, 2006 7:28 pm
Hi Aaron and welcome to the forum.
It sounds like the boat is still under warranty. You may wish to establish yourself with a local dealer who can work with you in correcting any hull leak issues. Perhaps someone on the forum from your area may have a recommendation. In the meantime, you can melt a little plastic in the hole or plug it with calking or glue to temporarily solve your problem.
Do you know if your Adventure came with the standard rudder or the larger sailing rudder? The larger rudder presents a challenge for the Twist & Stow mechanism and a little hand assist is not uncommon. In either case, there are a couple of things you can do:
1. Some silicon spray periodically in the rotating mechanism helps keep the friction down.
2. Wiggling the rudder with the directional control while lifting it helps get it going.
3. Your boat may have a loop bungee on the lifting side of the cables. Hobie has recommended changing that for a loop cable. There may be a free kit available for that.
4. It's possible, but not likely that your rudder can be adjusted too tight or too loose. It should not bind as you rotate it by hand, but not be sloppy either. If your dealer is familiar with the system, he should be able to troubleshoot it for you. 8)
