It is currently Fri Apr 26, 2024 12:16 am
 Post subject: Missing jib batten???
PostPosted: Thu Jul 11, 2013 5:35 pm
I just got an older hobie 16, and the jib is missing the lower most batten. I am a beginner so, other than a loss in performance, will a missing lower batten cause any issues?
PostPosted: Fri Jul 12, 2013 7:17 am
I lost the top one 2 weeks ago. I noticed the jib luff's alot unless pulled in really tight......... Got a new one on order, not expensive, be sure to order a cap also.
PostPosted: Sun Jul 14, 2013 5:13 am
Hi ebs675,
I orded some 15mm wide generic batten from my local chandler and he threw in some end caps not the Hobie cleat type end caps but heyho.
I lost batten 2/4 and 3/4.
Cost for 3 meter of batten £2.50 (I'm in the UK) the Hobie battens though more desirable are around £20 each so around £40 plus delivery for the two. These are probably much cheaper in the US. I will probably end up buying a complete set but the above for now works perfectly fine.
I am a complete newbie and I had my maiden outing yesterday. An amazing experience.
I hope you enjoy your Hobie :-)
SRG
Hobie 14 Turbo (~1979)
Hobie 16 Carumba (1983)
Hobie 16 1990 (storm damaged)
Hobie 16 1996 (my latest)
