It is currently Fri Apr 26, 2024 10:13 am
 Post subject: Remove mounting boards
PostPosted: Thu Aug 01, 2013 8:16 pm
I have a 2011 pro angler 14. Anyone have any advice on accessing the nuts in order to remove the mounting boards? I have a mod in mind but only if I can remove the boards then get them back on.
Fish heads. Fish heads. Eat them up. Yum!
PostPosted: Fri Aug 02, 2013 8:46 am
If it's the same setup like my 2012, the 2 front screws have nylon nuts on the back sides. You would have to take the rod tunes out to access those screws as it can't be done while the rod tubes are installed. On the 2013 model they made all the mounting board screws going into recessed threaded bases so it's a lot easier to remove them.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Mon Aug 05, 2013 7:58 pm
I was actually able to reach the nuts using a socket and a long socket extension. Removing a the rod holders is a huge pain.
PostPosted: Tue Aug 06, 2013 11:34 am
Authorized Hobie Dealer
Removing the rod tubes is a pain but the easiest way for accessing the nuts that hold the accessory boards on. Like TDK said you can probably finagle a wrench or socket in there too. Next time we have one go thru the shop I'll try to take a peek at it.
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
