It is currently Thu Apr 25, 2024 11:14 pm
PostPosted: Mon Dec 09, 2013 8:07 am
Was asked for some info on this set-up...so thought I would share it here.
Downrigger set up on my 2014 PA14.
- Frame made with 3/4” PVC.
- Arrows indicate, (2) 1/2” foam rubber gaskets (from an old bicycle handlebar)
- Nylon 1” strap with plastic clip/buckle.
- (4) Bolts, washers and wingnuts.
There is foam rubber glued to the underside of board (where it contacts PA hull)
PVC sits on rubber rest:
1" adjustable strap goes around bottom seat rail:
set-up below is used for trolling planer floats (off sides) and a regular float down the middle.
Rigged 'n Ready (just add water)
Link to the 2010 PA version:
viewtopic.php?f=78&t=47241
Regards, JoeyB
PostPosted: Wed Dec 11, 2013 5:27 am
Thank you!
badbill
2014 Hobie Pro Angler 14
PostPosted: Thu Dec 12, 2013 5:57 pm
Joey are you a Hardcore guy? I noticed Stew Rat took a picture in your video.
badbill
PostPosted: Sat Dec 14, 2013 7:18 pm
I have fished the Hardcore Invitational on the Catawba and some Carolina Yakfish tourney's with Stew-Rat.
PostPosted: Sat Dec 21, 2013 4:12 pm
love the set-up....fantastic job
