It is currently Fri Apr 26, 2024 12:04 am
 Post subject: h17 comp tip needed
PostPosted: Sat Aug 23, 2014 3:26 pm
hello, does anyone have a used h17 comp tip in good condition? just pulled my cat off the water to do the sport conversion and noticed a crack in the hull and a cracked comp tip. thanks, dan
 Post subject: Re: h17 comp tip needed
PostPosted: Mon Aug 25, 2014 3:55 am
How badly is it cracked? You may be able to fix it using fiberglass/carbon fiber and epoxy resin.
http://www.hobiecat.com/forums/viewtopic.php?f=20&t=44683
PostPosted: Mon Sep 22, 2014 3:02 pm
Daniel I have an full mast that I can't use - no boat. Happy to give the tip away rather than dump it. But the catch is I'm in Oz, and shipping is pretty spendy.
But if you can find a way of shipping at a reasonable cost from Cairns, Australia, I would happily send it rather than dump it.
Cheers
Geoff
