I initially thought the spinn pole was too high (there are very few pictures on the internet for comparison), but I have no control over the height as the cables from the pole to the bows are factory and I will assume they are the correct length.
The pole does sit below the bridal by roughly 18" and a bungee cord goes between the pole and the bridal.
There is not talk of pre-bend in the pole and I am not sure it's necessary with only 60sq feet of spinnaker.
I have not installed the tang yet; I only want to do it once. It is held on by tape for the test fit.
So, does the luff (is that what it is called on the spinnaker?) need to be tight between the pole and mast tang? It does not look correct as it sits now.
thanks for the input and I look forward to some more answers and perhaps a picture or two....
This is the best internet picture I can find and the front of the sail looks fairly tight between the mast and pole and the sail is not hanging to the side like mine; also the pole appears to be attached with rope and not cable and clips like mine...:
![Image](http://i13.photobucket.com/albums/a276/tradisrad/38999051_1.jpg)
This example of a somewhat similar boat and there is halyard above the head of the spinnaker. I think this is how it should be rigged. This would allow for varying the tension of the luff?:
![Image](http://i13.photobucket.com/albums/a276/tradisrad/adv4018.jpg)
