It is currently Mon Apr 29, 2024 9:05 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Thu Dec 14, 2006 9:45 am
Bob:
Here you go. This is a GREAT price. I paid $850 for mine 6 years ago !!!!! And this is better material that will not stretch as much. Kevin is a nice guy, call him.
Doug
This is the quote for the reacher you were asking about. I'll leave
the paperwork as an attached file, so feel free to forward this
message to whomever is interested.
Tri Radial Jib proposal:
Dimension P2MX Polyester Laminate
Sail Area 78sqft
I 17.2
J 8.43
LP 100%
Price with or without battens: $700
Get in touch with me if you or anyone is interested! We can have the
complete sail shipped easily within three to four weeks.
Kevin Taylor
Sail Consultant
UK/Halsey Sailmakers - Texas
972-693-3155
PostPosted: Fri Dec 15, 2006 7:56 am
Doug,
excuse my ignorance but I don"t know what this numbers mean: I=17.2
J=8.43 and LP=100%.
 Post subject: Call Kevin
PostPosted: Fri Dec 15, 2006 10:58 am
Bob:
Call Kevin, he can explain that I am not a sailmaker and don't know what they mean either.
Doug
 Post subject: Sailboats 101
PostPosted: Fri Dec 15, 2006 11:34 am
Boat builders, sailmakers and riggers use the following four measurements to determine sail size. I, J, P and E.
Headsails
"I" = distance from the base of the mast to the where the forestay attaches to the mast
"J" = distance from tack pin at the lower end of the forestay to the front end of the mast
With those two measurements headsails and spinnakers can be developed.
If a spinnaker pole is longer than "J" then the measurement is refered to as "Jc" with the "c" standing for corrected.
If the spinnaker hoist is higher than the hounds then it is known as "Ic"
"LP" is the Luff Perpendicular and is expressed as a percentage of "J" 100% Jib or a 155% Genoa on a keelboat.
Mainsails
"P" is the maximum usable area of the mast from the boom to the top. Generally refered to as the luff length of the mainsails.
"E" is the maximum usable area of the boom from the mast to the rear of the boom
In most cases the measurements are in tenths. 8'6" is 8.5'
Hope this helps,
Chip Buck
________________________________________________________
SailMaker
PostPosted: Fri Dec 15, 2006 12:29 pm
Chip,
WOW, thank you!
By the way: square top main I've purchased from you this year works great. It just needs a liitle brother jib. :D
Bob.
PostPosted: Fri Dec 15, 2006 6:44 pm
Chip:
If the is Chip from Whirlwind Sails, did you get all the email's I sent you about referrals ? Still waiting for my Chili's Gift Certificate?
Doug Snell
dsnell4 at houston dot rr dot com
PostPosted: Wed Dec 20, 2006 10:33 am
Doug,
At Murrays page they offer 30-5104 Hardware Kit for $860 and 01-1350 H17 Crossbar Assy. for $250 which makes total of $1100 plus jib, while Hobie Catalog offers ALL (I believe) for $809 plus jib.
 Post subject: Trust me
PostPosted: Wed Dec 20, 2006 4:44 pm
Bob:
Trust me I have done a LOT of research on this. The kit:
http://www.murrays.com/archive/41.pdf
Comes with the bridle foil and all the parts you need. It ALSO includes the 18" tracks with the cars and the Hexarachet Harkens that you will need for the reacher. you DON"T want the stock jib, TRUST me I bought one and tried it. You won't be happy with it. If you want BIG gains in performance get a squaretop main and a reacher. I am probably the most knowledgeable person on the matter and the 17. I have already spent the money and made the mistakes.
Doug
