It is currently Sun Apr 28, 2024 2:56 am
PostPosted: Wed Mar 23, 2016 8:15 pm
I installed the furling kit on two of my Revos but I have Yak Attack tracks that the furling control lines rub on (leading edges). Are there taller fairleads that I can buy to clear the tracks, or should I jerry rig some sort of smooth, angled ramp to cover the square edge of the track?
Also, it's a bit tough to get access to where I want to bolt on the pad eye for the control line bungee to hook on to. If I insert a Hobie rod holder I can hook it on to one of the molded loops. If I secure the holder to the hull with another cord, I think I can get away with not having to drill any more holes in my hull. Any issues with this idea?
Thanks!
PostPosted: Mon Mar 28, 2016 11:52 am
Anyone? Matt?
PostPosted: Wed Apr 27, 2016 12:35 pm
staktup-
Here is what I did. I rollerized my furling system by mounting Harken Cheek pulleys on the front and a regular Carbo Air on the rear instead of just going through the ring. The front pulleys are mounted on a Yak-Attack JK Hatch Accessory Plate- http://www.yakattack.us/AAP_1022_p/aap-1022.htm
Everything is out of the way and MUCH Smoother!
PostPosted: Sat Sep 17, 2016 8:21 pm
Thanks Browneyes,
Mine is less elaborate (ghetto really) than yours, but gets the job done. Cutting board riser.
[url]<a href="http://s296.photobucket.com/user/Staktup/media/Mobile%20Uploads/image_zpsjaknedzo.jpeg.html" target="_blank"><img src="http://i296.photobucket.com/albums/mm175/Staktup/Mobile%20Uploads/image_zpsjaknedzo.jpeg" border="0" alt="elevated fairlead photo image_zpsjaknedzo.jpeg"/></a>a[/url]
[url]<a href="http://s296.photobucket.com/user/Staktup/media/Mobile%20Uploads/image_zpsmlgobkj1.jpeg.html" target="_blank"><img src="http://i296.photobucket.com/albums/mm175/Staktup/Mobile%20Uploads/image_zpsmlgobkj1.jpeg" border="0" alt="elevated fairlead 2 photo image_zpsmlgobkj1.jpeg"/></a>[/url]
PostPosted: Sat Sep 17, 2016 8:30 pm
Thanks Browneyes,
PostPosted: Mon Sep 19, 2016 9:25 am
staktup wrote:
Thanks Browneyes,
This isn't going to furl with the downhaul bungee going to the boat - it's supposed to rig to the hook on the top of the furler drum.
Jacques Bernier
http://www.hobie.com/
PostPosted: Mon Sep 19, 2016 5:00 pm
Thank you, I discovered that mistake after I took pictures and sailed for a bit :oops:
cron
