It is currently Sat Apr 27, 2024 5:43 pm
PostPosted: Mon Mar 20, 2017 4:32 pm
I have searched this topic and found no mods to be able to control the dagger board from the rear seats. Im pretty sure there is a mod out there. Please point me in the right direction.
Sent from my SM-T350 using Tapatalk
PostPosted: Mon Mar 20, 2017 5:31 pm
MrMako, at this year's Everglades Challenge, had the setup to lower/raise the centerboard from the rear seat shown here
PostPosted: Mon Mar 20, 2017 7:17 pm
I have a small rope loop at the end of the paddle. Loop around the centerboard knob to pull it back (down), just use the end of the paddle to push the knob forward to retract.
PostPosted: Tue Mar 21, 2017 4:28 am
What do you guys think about this contraption?
Sent from my XT1585 using Tapatalk
PostPosted: Tue Mar 21, 2017 6:05 am
I like this set-up. How do you get it to lift out of the lock position?
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Tue Mar 21, 2017 6:40 am
I try to weigh the complexity of something against the actual benefit or savings in effort. For now, I just get up and move to the front of the rear cockpit to raise or lower the board.
PostPosted: Tue Mar 21, 2017 7:02 am
I like this idea, here's a good example of it being done - http://www.seqic.com.au/hobie-adventure ... d-control/
Although, I'm with Tom K, I just get up when raising and lowering the centerboard. I'm usually up and moving around the boat anyways, so it's not too inconvenient for me.
-- Chad | 2014 TI
PostPosted: Tue Mar 21, 2017 9:15 am
Thank you, I knew someone must of came up with the same idea.
PostPosted: Tue Mar 21, 2017 9:39 am
You have to be a little more careful with that as the CB wont kick up on its own in a grounding with the cleat.. Maybe add a bungee in series with the line so that something will give?
PostPosted: Tue Mar 21, 2017 10:31 am
Touayang84--too complex. This is a simple task. We have Tom Kirkman's and MrMako's solutions.
PostPosted: Tue Mar 21, 2017 2:31 pm
I teach soldiers how to fix and troubleshoot turbine engines. It's never too complex.
PostPosted: Tue Mar 21, 2017 3:09 pm
I think we are going to need a new thread now..
How to mount a turbine jet engine on a TI..
PostPosted: Tue Mar 21, 2017 3:40 pm
Hmm, this could be the answer that I've been looking for to make my boat faster...
-- Chad | 2014 TI
PostPosted: Tue Mar 21, 2017 4:56 pm
FYI the T55-GA-714, pictured, makes over 4000 shaft hp continuous at 100% N1
PostPosted: Tue Mar 21, 2017 5:40 pm
I've got you beat. Used to R/I F110-GE-129 engines in F-16's...they have 29,000 lbs of thrust...and an afterburner. Lol!
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
