It is currently Fri Apr 26, 2024 12:18 am
 Post subject: Boom Tent on Wave?
PostPosted: Tue Mar 14, 2017 2:35 pm
Hey Guys,
Just thinking of all the sail camping I want to do this summer on the Wave. I have grand plans and have been doing some reading of various sorts. Folks talk a lot about boom tents and this sounds great.... EXCEPT I own a wave and have no boom (No Boom for you!)
I was wondering if anybody has made a "Boomless" tent?
I was thinking a large Poly or canvas tarp with a D Ring installed 1/2 way and a fiber glass tent pole attached at midpoint. Then raise or lower using Halyard and pull out and stake to ground/ sand using light line to grommets. Sounds simple enough right? Any other ideas or simpler ideas?
Nick
 Post subject: Re: Boom Tent on Wave?
PostPosted: Tue Mar 14, 2017 3:39 pm
Just get a self-supporting tent and some ties to anchor it to the tramp lacing. Here's a small 1-person tent: https://www.rei.com/product/879885/the- ... eak-1-tent
They also have a 2-person that is almost the same size as the tramp.
PostPosted: Sun Mar 19, 2017 10:49 am
The tent on the tramp is an Idea I have considered. However, If I am going to camp in a tent I would probably pop it on the beach. The other consideration I had was no tent an less weight, no poles, just rope and tarp. Not sure though if others have had no luck with this.
PostPosted: Sun Mar 19, 2017 12:26 pm
Would sleeping under the wave (when on land of course) work for you? Drape a tarp over the tramp and both open ends between the hulls.
PostPosted: Tue Mar 21, 2017 5:18 pm
That sir is BRILLIANT! I need to find out if my fat tail can fit underneath! :D
That would be super easy. Two tarps would be a solid idea to keep off ground. Even just some plastic sheeting would work. GREAT Idea!
PostPosted: Wed Mar 22, 2017 6:39 am
I'm glad you like that idea. If you need more room, maybe lay the wave over on it's side and make a lean-to with some tarps.
