It is currently Mon Apr 29, 2024 4:10 am
PostPosted: Thu Aug 24, 2017 6:44 pm
I have a 2017 Outback that I've been using very actively for three months. Today I noticed something unusual for the first time when I took it out on a calm day on relatively still water.
The rudder is in the down position for all of this. When I pedal, the kayak starts to veer to the left and I have to compensate by moving the rudder steering lever right. Once I stop pedaling and "coast", the kayak starts to self-correct and track to the direction indicated by the steering lever as it slows down. Start pedaling again and it pulls to the left again. It also felt like the kayak wasn't aligned parallel to the direction of travel. This behavior was present regardless of direction I was going in the water (I think this rules out currents). I checked the rudder as best as I could, and redeployed it multiple times (I've noticed in the past that if it isn't fully deployed it doesn't track properly). The MD 180 looks to be in good shape. Checked for bent mast rods, tension dial mismatch, or other misalignment and it looked ok. I eyeballed the bottom of the hull for any dents or irregularities and didn't notice anything immediately obvious. I have the larger sailing rudder installed.
At one point in trying to troubleshoot, I raised the rudder to see what would happen and the kayak started to do a very tight spin to the left (as if the rudder was down and fully turned left). I don't know how reliable this test is, since I also got it to turn to the right sometimes if I raised the rudder while turning right.
Would appreciate any tips on what to check that may be causing it to pull to the left. Thanks
PostPosted: Fri Aug 25, 2017 7:57 am
You must use the cleat to lock it down – in the cockpit – near the bottom of the mesh pocket on the right side is a small black cleat – place the line in the cleat – that is what holds it down.
If it isn't cleated and lifts even a tiny bit it starts to turn left - as the rudder raises it flips up onto the deck towards the left.
With the rudder fully out of the water the boat would go in circles - yes, that is correct.
Most important thing - cleat the rudder down. You might think it's staying down but it can be lifting a little - which turns left.
The manual shows this on page 10 https://docs.google.com/viewer?url=https%3A%2F%2Fstatic.hobiecat.com%2Fdigital_assets%2Fmirage-kayak-manual-150828.pdf
Jacques Bernier
http://www.hobie.com/
PostPosted: Fri Aug 25, 2017 8:32 am
I have been cleating the rudder. I learned to do that after about the second time out. I confirmed that while it was cleated that it was firmly positioned and resisted lifting. Anything else to check? I will also try putting the standard rudder back on to see if the one I'm using is damaged.
PostPosted: Fri Aug 25, 2017 12:46 pm
Given it seems to be worse when you actively pedal what happens if you paddle it? Try rudder up and down, included having the handle wedged in position? Is it turning one way or the other still dominant to same effect. Be aware of your tenancy to paddle more strongly on one side vs the other.
Ideally if you know someone else with a hobie swap drives to eliminate drive problems
Also find rudder position that holds it straight. Wedge in place, then hop out in shallows and eyeball rudders actual position.
Also try leaning substantially to either side and see how much that affects turning each way.
PostPosted: Fri Aug 25, 2017 1:58 pm
There are a couple of possibilities:
1. Your fins may be biased to one side. To check this, hold the Drive upside down by the crank arms, with the front of the Drive pointing toward you so you're looking at the fins head-on. The fins should be straight up if the pedals are exactly together. If the fins are slightly split, that is no big deal, but if they are both leaning to one side slightly, the Drive's thrust could be off centerline. To correct this, you would ease cable tension for each fin on one side and take it up by the same amount on the opposite side until the fins are in-line with the crank arms.
2. With the Drive inserted in the hull and the hull upside down (perhaps on a pair of saw horses) look at the axis of the fins compared with the axis of the hull. It's rare but possible that this could be marginally off. In this case, there isn't much you can do about it. The rotomolding process provides some small individual variation in the boats during the extraction and cooling process that is unavoidable because of shrinkage. The operational result is negligible.
As jbernier says, the boat always turns left when you raise the rudder. This is a feature of the Twist N Stow rudder. I use this feature when coming to shore, pulling the rudder up just before landing to present the starboard side to the shore, which is where I exit the boat. Very handy!
You should know that all the Mirage Drive Hobies are directionally unstable in forward motion because they have no skeg. They will turn in either direction depending on the initial input; the shorter the boat, the greater the effect. The boats are directionally stabilized by the rudder alone. Not having a skeg gives the rudder more authority to turn the boat so you get better handling. That's also why the large sailing rudder works so much better than the small rudder. This is also why the boats don't track well without the rudder down and locked. Note that all Hobie paddling boats may look similar but they all have a skeg for better tracking.
To that end, It's always good to check your directional rudder lines -- they should be taut (but not tight) when the rudder is down, locked and pointed aft. If there is slack in that position, the boat can wander, causing frequent corrections. Since the hulls expand and shrink slightly due to temperature, it's good to check this during the seasons as temperatures change. It's easy to adjust the line on the appropriate side with a Phillips head screwdriver. The rudder line itself is made of Spectra, quite strong and very length-stable. 8)
PostPosted: Mon Sep 04, 2017 11:19 am
Thanks all for the help. I tried swapping out the rudder for the standard rudder and there was no difference.
When I got home where I could put the kayak up on sawhorses, I saw that the rudder didn't look like it was tracking straight with the lever in the straight position. After adjusting the rudder lines with the two screws at the back, it seemed to help a lot. I was able to get the steering to feel like it used to. It took a couple of cycles of adjustment followed by testing in the water to get it right. I'm not sure if it was because of the line stretching a little bit after 3 months of hard use (as a newbie I tended to make mistakes such as dragging and banging the rudder). Also I took it in rough water a few times and if the currents were forceful on the rudder, may have helped contribute.
All good now though.
PostPosted: Mon Sep 04, 2017 8:40 pm
Hobie's Twist-n-Stow Repair Manual, which is available at https://static.hobiecat.com/digital_ass ... 1504278546 , indicates that the steering control on a Hobie kayak should be adjusted so it is centered in its range of motion, not pointing straight ahead, to make the kayak track straight ahead. Specifically, the manual says "With the tiller (control handle) centered in its range of motion, the boat goes straight. Note: typically the 'centered in range of motion' is actually pointing to the right at about 20 degrees." Later in the instructions, the manual says "Center the steering control handle in the middle of its range of motion. This is typically when the control handle is pointing 20 degrees to the right."
PostPosted: Mon Sep 04, 2017 8:46 pm
Yeah, I figured that out the hard way too, thus the multiple trip/alignment sessions. My first attempt was to align it straight ahead and that was a mistake. Nothing was harmed, and I learned a bit about rudder alignment in the process.
Thanks for pointing this out.
