It is currently Fri Apr 26, 2024 12:03 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: Compass question
PostPosted: Wed Dec 13, 2017 9:40 am
Hello all, I'm looking pretty hard at the new compass. I had a PA14 years back, but always felt it was a little too much for my fishing style. I then got a 2015 outback and felt it was the perfect boat. Sold my outback last year to get a tandem paddle kayak for my son and I, but I really miss my hobie.
I really like the new compass and the reviews I'm seeing, but I saw a review stating that the deck around around the seat was flexing some, just curious if anyone has experienced it, or if it was an early-release and not a properly outfitted boat (foam blocks, etc). I do plan to add the square hatch if I get one, maybe that makes a difference?
 Post subject: Re: Compass question
PostPosted: Wed Dec 13, 2017 10:05 am
The rectangular hatch will add some rigidity to the deck. Reports of deck flexing you're hearing about could potentially be a result of misplaced foam. Keep in mind, you can always add more foam under the sitting/standing area of the cockpit if you feel it's necessary. Using pool noodles, cutting them to the proper length and taping 3 or 4 of them together is a great way to DIY your own foam inserts.
Howie Strech
Parts & Accessories Product Manager
PostPosted: Wed Dec 13, 2017 11:15 am
Agree with what HStrech said. I took mine out before installing the square hatch and had no issues whatsoever. I'm 230 lbs for what it's worth. I also agree that it could have been foam placement but really don't see any issue with the Compass decking.
PostPosted: Wed Dec 13, 2017 12:02 pm
Sounds good. The one thing I didn't like about my outback was having the seat adjustment straps rub a blister on occasion. Seems like the compass seat is wider and shouldn't have that effect (on my big rear).
PostPosted: Wed Dec 13, 2017 12:31 pm
Have 6 trips and almost 45 hours on my Compass inshore in the Gulf. Love it! You will too! :wink:
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Wed Jan 10, 2018 12:48 pm
I got my compass yesterday and purchased the standard plug in cart. The cart instructions state that the kayak should rest on the collars and the support bar of the cart, but I can't get the collars to go low enough for the bottom of the kayak to rest on the foam support bar. If the kayak sits only on the collars, is this okay? I only use the cart occasionally to launch and when I clean the kayak up after a trip. It never sits on the cart for long.
PostPosted: Wed Jan 10, 2018 1:37 pm
I would think you should be fine. The scuppers are re-enforced. Will have to look at mine. I used my HD cart I had for my 2013 PA14. No issues so far. :wink:
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Wed Jan 10, 2018 2:27 pm
I just noticed the Hobie Fold n Stow cart doesn't have a crossbar for the boat to rest on, so I assume I'll be alright. I used to have a 2013 PA and had the PVC shims on the cart, I believe it was to prevent the kayak from sitting on the crossbar. Seems like it should be fine on a compass, but just curious.
PostPosted: Wed Jan 10, 2018 2:46 pm
The shims on the PA cart was to prevent the black collars from sliding all the way down and causing the wheels to rub against the hull when in use.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Thu Jan 11, 2018 11:46 pm
Not sure it doesn't put out of shape the hull over time... :(
François - French Hobie fishing team - Outback 2019 papaya
ex: Revo 13 2007 - PA 14 2008 - PA 12 2009 - Outback 2011/2013/2015 - Compass 2017
PostPosted: Tue Jan 23, 2018 12:56 pm
I have had a hard time with the paddle holer while out on the water. Has anyone come up with a better solution to paddle storage? I see mariner sails has a cool looking idea on their "Pro" version. Has anyone tried it? Is it as simple as removing the bungee bases and screwing in the taco clips?
One of my favorite things about the compass is the ease of fishing sidesways and hanging my legs in the water. On the paddle side, I always end up kicking the paddle out of the bungee.
thanks
PostPosted: Wed Jan 24, 2018 12:39 am
I don’t see this as a Compass problem. I installed taco clips on my Outback and my bitter half’s Sport. Left the bungee alone, might come in handy some day.
PostPosted: Fri Jan 26, 2018 7:51 pm
I just bought a compass tonight. I found the seat straps to be just a little too short resulting in a very upright seated position even when adjusted to full extension. My dealer just gave me traditional brass kayak seat clips that essentially allows a couple more inches of seat reclining adjustment so the top of the seat frame doesn't put too much pressure on your back. I also agree that the fore deck is quite flexy and I'm only 200 lbs. I plan on adding more foam support soon.
PostPosted: Fri Jan 26, 2018 9:21 pm
The short straps were a known issue. Hobie has changed the design and your dealer was supposed to have switched them for straps that were the right size. I would contact your dealer.
PostPosted: Fri Jan 26, 2018 10:42 pm
I changed them as soon I got the kayak, as they don't allow you to put any stuff under the seat. :(
Just cut, make a solid knot and that's it!
