It is currently Sat Apr 27, 2024 1:22 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: My Compass Setup
PostPosted: Mon Jun 04, 2018 9:38 am
I'm not too worried about the waves. Where I fish its relatively calm and secluded from wind. That's encouraging that you spent that long in the seat and was good to go. That's really my biggest concern right now is the seat. I know Im spoiled with the PA seat but I'm hoping this one comes close.
PostPosted: Mon Jun 04, 2018 12:26 pm
Steve could you post a photo of the bottom of your modified seat pad?
Dave
PostPosted: Mon Jun 04, 2018 1:22 pm
Dave
Let me get home tonight and take some pictures. Will post them here.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Mon Jun 04, 2018 4:36 pm
All,
Since I was asked to share pictures of my seat cushion solution here are a few. The issue for me with the Compass seat was that my rear end kept resting on the rear seat base. Even though I tightened the back lumbar as tight as it would go, my posterior still rested on that rear bar. Not comfortable. :(
So I happened to have one of those square marine throw cushions from my bass boat days. It has 2 pieces of foam inside. I cut a long slot on the bottom and removed one of the layers. That left the perfect amount to provide comfort and keep me from feeling the seat frame.
Using some black Gorilla tape, I taped up the bottom so the slot I cut was covered and the loose material was secured. I then wrapped the straps around the seat base and used a small shock/bungee cord to hold it in place.
Installed the new cushion works great, provides the right amount of cushion without feeling like I am sitting higher. Since the cushion is marine grade, I don't worry about it getting wet and it's easy to take off and clean. :wink:
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Mon Jun 04, 2018 6:26 pm
Thank you :D
PostPosted: Fri Jun 08, 2018 6:38 am
Are the H rail secure enough to lift the Compass with the rails?
PostPosted: Wed Jun 13, 2018 5:09 am
Mine are. :wink:
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Wed Jun 13, 2018 5:41 pm
Steve,
I really like your Compass, beutfully set up, and it really looks functional. I’ve had an Outback in the past, a 2005, and I have Ocean Kayak 15.5 foot Prowlers, but I want a new Hobie, and the Compass looks like the one I would like, size, smaller than the Outback, and easier for me to handle. I’m small, 5”6”, 155 pounds.
Did you do all of your own work, mounting all gear, etc.? Have you had any problems? Has the power pole given you any problems? Do you use it much and how well does it function for you? Are the floor pans worth the investment? Sorry for the questions, but I’d like to avoid mistakes.
I am generally a minimalist, but I’ve thought in the past about decking one out fully, and I love the looks of your’s.
With all of the add-ons have you calculated your investment. Just guessing with power pole and all, I’d estimate $3,500.00 to $4,000.00. I was trying to figure out what I would have to invest to have one similar to your’s.
One last question; have you had your’s in saltwater? If so, how did it do with the waves and wind? I am in Central Texas and fish the lakes and rivers here, Lake Waco in Waco, Texas and the Brazos River, but we also fish the flats around Arkansas Pass and off PINS (Padre Island National Seashore) on the Gulf of Mexico. It can be quite or it can be rougher, so I’d need something that can handle launching in the surf and wind and waves away from land.
Thanks for your help. I really will appreciate your thoughts, and I really think you have done a great job on your kayak.
Ray
Harold Ray Emerson
419 Lake Air Drive
Waco, Texas 78710
Phone: 254-772-3520
PostPosted: Thu Jun 14, 2018 6:08 am
Harold ray wrote:
Steve,
Ray
Ray,
Sent you a PM. Happy to discuss details and answer questions over the phone. I have only fished saltwater in the Compass. Most of the time it's Gulf inshore in the Big Bend area of Florida. About 130 nautical miles on it now...lol!
Steve
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Wed Jun 20, 2018 7:40 am
SRAces wrote:
LoneWolf wrote:
Very nice rig! How do you like the seat compared to the PA seat? Have you tried standing yet?
I have a 2017 PA 12 and like it except for the weight. Its overkill for where I fish and I'm thinking about selling it and getting a Compass.
The only thing I miss using the Compass is the skeg of the PA. That skeg helps keep your stern from being blown around by the wind.
Steve, do you not have the rudder deployed in that scenario? It seems like the rudder would keep the ass end from blowing around...Thanks again for this great thread, I have nearly gotten the approval from the wife to order a new yak, so I am again doing my due diligence.
PostPosted: Wed Jun 20, 2018 9:01 am
Even with the rudder deployed, the stern can get pushed around. I do have the Blackpak behind the seat and that can act as a mechanism to help the wind push the rear around. I don't use a drift chute, but have been debating whether to get one for times when I am slow fishing over grass beds in the Gulf. In the Pro Angler the skeg really helped keep the rear from swinging around when you were going slowly and working an area with angled winds. The rudder on the Compass is nowhere near the size of the PA rudder. :wink:
Keeping the fins up helps to an extent as there is less resistance on the front to allow the rear to swing if there is a crosswind. Not complaining at all regarding the Compass. It's my main fishing machine for the time being. Just an observation. Took the PA14 tarpon fishing last weekend. Going to try the Compass this coming weekend.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Mon Aug 20, 2018 10:12 am
BerleyPro Jig Bucket Edition Side Bro
Sent from my iPhone using Tapatalk Pro
PostPosted: Mon Aug 20, 2018 10:34 am
That looks nice!
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Fri Aug 24, 2018 11:32 am
You have the cleanest and most fishable set up I have seen. Two questions; 1. Whats the parts makeup of your rod holders? Seems to be the universal H rail plate and either scotty or railbalza. I can't find the rod holders anywhere. 2. What do you use the empty side mounted plate on the blackpak for?
Cheers! 8)
VR
Jeff
PostPosted: Mon Aug 27, 2018 5:13 am
Cheers! 8)
VR
Jeff
Jeff,
The rod holders are the Ram Junior (YakAttack Zooka Tubes) with the RAM lockable bases. Go to "themountdepot.com" and type Ram Jr in the search box. Looks like they are temporarily out of stock. Normally run $24-$25 for the holder and the mount. It's a simple setup that I started with on my Pro Angler that allowed me to put the rod holders anywhere I wanted along the H-Rail. Yes, I used 2 of the Hobie universal mounting plates to mount the rod holders to. I put the holders on the H-Rail just behind the seat on the Compass. I can basically rest my arm on the rod holder. When landing a fish in the kayak, I just open the bail and drop the rod in the holder. Keeps the rod secure and out of the way while I unhook the fish in the kayak.
I normally pivot the right side around the 2:30 clock position. That allows an easy angle and keeps the rod butt angled where it doesn't interfere with anything. The left side is normally straight back top the rear or slightly outward. Allows for me to keep a second rod handy and easily swapped out with the rod I am throwing versus twisting around to get a rod out of the Blackpack rod holders. The red phone cords are safety leashes so if I happen to pull the rod holder out to re-adjust the angle and drop it, I won't lose it!
The mounting plate on the side of the Blackpak is for a Navisafe telescoping pole that either holds the magnetic attached 360 light at the top or my Fuji XP70 waterproof camera. I did add 2 more rod holders to the Blackpack since the pictures were taken. So I can carry 6 on the Blackpack when I am tournament fishing.
Thanks for the compliments on the setup. About 175 nautical miles on it so far and still loving it!
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
