It is currently Sat Apr 27, 2024 8:36 pm
PostPosted: Thu Dec 06, 2018 12:42 pm
On My Tandem island 2015, the rode for the adjustment position of the front seat is stuck in height position since a year.
I thought it was just a mechanical problem and because I use it in height position only, I leave it like this.
I rince this part with fresh water after each use and never see any corrosion at this point before.
Now I am discovering, the rode swollen and cracked. (see pictures)
Where you can see a white mark, the rod is opened and corroded.
There is clearly a corrosion issue from inside who made the rod inflate and cracked.
I read on other post it could be a broken spring, but I am very surprise of a such effect.
I send this case to my retailer and I don't even know the part number for this.
Do you know how it's made inside and how to prevent this, because fresh water and moving it time to time was not enough for me.
I have to wait to receive the replacement part before investigate because I thing removing this rod will be destructive.
I just notice the crack increase between those pictures, it was just a trip of 3 hours.
Cheers,
Olivier
PostPosted: Sat Dec 08, 2018 4:41 am
Is it possible that water was trapped inside and then froze causing the crack?
PostPosted: Sun Dec 09, 2018 6:02 am
I live in south of France, No frozen temperature since last February and my kayak is sleeping indoor.
The minimal record temperature was 6°C in November this year. ( 43°F )
PostPosted: Mon Dec 10, 2018 10:14 am
That is corrosion from trapped salts.
