Picked up a 21SE and purchased all new rigging from salty dog, the mast rake seems very high. Is this normal? I’m used to virtually zero with my old H18.
The taper pins have a large space between nut and crossbar, does this mean the holes are worn and taper pins are sitting deeper than originally designed? I dont think it's a big deal as the taper pins a frozen in place.
Also are there any other items I should replace? For example on the Hobie 18 I know it’s good to replace the shroud anchor pins. The ones on the 21 are substantially beefier.
If anything is sloppy like rudders or traveler car I will rebuild/replace it, I just want to make sure there isn’t anything that should be replaced as a safety issue. Thanks!!
![Image](https://i.imgur.com/lHgyc67.jpg)
![Image](https://i.imgur.com/X8pRm1T.jpg)
