It is currently Sat Jun 15, 2024 8:39 pm
 Post subject: Hobie Bob Hardware
PostPosted: Wed May 13, 2020 1:52 pm
Matt M. I recently acquired a Hobie Bob 30113, however it didn't come with any of the mounting hardware, rivets, washers or lock ring. It did come with the aluminum pole. Any chance I could order these parts still from you guys? If not, any idea on the sizes of the eye straps and the long rivet?
Thank you,
Adam
 Post subject: Re: Hobie Bob Hardware
PostPosted: Wed May 13, 2020 4:25 pm
You can order from a dealer. There is the kit of parts 30118:
PostPosted: Wed May 13, 2020 4:43 pm
Wonderful, thank you so much.
PostPosted: Thu May 14, 2020 10:32 am
Is this still available, I don't see this available on your website.
Thank you,
Adam
PostPosted: Thu May 14, 2020 11:36 am
Not so minor detail! Sorry!
"WHERE USED" --> Description Qty
8003291 PVC PIPE 3/4 X 10' SCH. 40 0
8010121 RIVET POP 3/16x5/8 PH-SS 2ea
8010141 RIVET 3/16 x 3/4" PH-AL 1ea
8010181 RIVET POP 3/16x1/4 PH-SS (ABA) 4ea
8011291 RIVET CAP 15/64 SS 3ea
8080711 WASHER 5/8x1-5/16 SS 2ea
36600031 BEARING 5/8 X 1-3/8 X 7/16 2ea
36600040 COTTER RING 1-1/8 X .072 1ea
H137 EYESTRAP-LRG SS 2ea
PVC can be sourced and cut to length... just spaces the float above the mast head.
We have all the rest in stock it appears.
PostPosted: Thu May 14, 2020 4:33 pm
Matt,
I'm installing this on a H18SX.
Can you clarify, why are there 7 pop rivets, but only 5 holes to drill? Also is there a reason to drill into the casting at the top of the mast as shown on the installation instructions vs just putting them in on the upper part of the mast but below the casting? Also is there a reason why the long rivet is aluminum vs stainless steel?
Thank you so much for all of your help,
Adam
PostPosted: Thu May 14, 2020 4:48 pm
Rivets are best into the aluminum for strength.
Long aluminum simply holds the rod vertically in the eye straps.
I don't recall the number of rivets other than in an aluminum mast... the shorter would be used in all four eye strap locations.
