It is currently Sun May 12, 2024 9:59 am
PostPosted: Wed May 16, 2012 6:20 pm
I was out sailing today in fairly strong winds when I heard a squeaking sound coming from the base of the tripod. I looked over and was shocked to see that the base had moved out from the boat, exposing a significant part of the threads on the bolts that hold everything together
The design of this system allows the bolts to come quite loose without any visual clues, because the bolts are hidden behind a cover plate/
I didn't get a picture of things when they weren't right, but
PLEASE CHECK THESE BOLTS ON YOUR BRAVO
It's a simple 2 minute fix.
Unscrew the screw on the cover plate, and tighten the two bolts with allen keys.
My boat is a 2008 that I bought used. I should have known to check these bolts, but the tripod always seemed very secure, I just never got around to it. I discovered today that the tripod can still appear secure while the screws can back out significantly. There are no visual clues that the screws are loose because they are hidden by the cover plate. It wasn't until I was in strong winds that the flex of the entire boat caused me to see the threads of these screws between the boat and the tripod.
It was pretty scary because I was out on cold water, had to get in, and had no idea how much of the bolt was left secured in the boat. I also didn't have the allen key that I would have needed to tighten them, or the screwdriver that I would have needed to get the cover plate off. Lessons learned.
So if you have a Bravo, take a minute to check these hidden bolts. Don't be like me! :oops:
PostPosted: Wed May 16, 2012 6:22 pm
I use loctite on our two Bravos to secure these bolts.
PostPosted: Fri May 18, 2012 11:48 am
Same here, I also always check them after flogging the sail a lot in a windy day. I think the constant shaking gets them loose.
PostPosted: Fri May 18, 2012 1:27 pm
Hobie Tech / Moderator
There is Loc-tite included in each boat that should be used when the frame is bolted to the boat. It's definitely a good idea to inspect bolts occasionally.
Brendan Castile
PostPosted: Sat May 19, 2012 3:25 pm
Had the same experience with the A-frame (tripod), but less dramatic. My wife was onboard when we were starting out, and said “Hey, this is loose...” First time, I tightened the hex bolts. Second time, I used up the last of the Loctite, and used a few drops per bolt. THIRD time (I like to dig into the swells, causing a lot of pounding and vibration), I coated the bolts with Permatex Threadlocker "Blue", which is available at Canadian Tire, and is the same as Loctite. No problem since, but if I do, I’m going “Red” (“Red” = permanent; “Blue” = medium strength).
Bottom line in all this is to check all screws/bolts/lines/drain plugs etc before “go-time”, and then recheck if you’ve been out for some time or in significant sea/swell/wind conditions. I give the port and starboard base of the A-frame a couple of good tugs to ensure the bolts are tight. And you have reminded me to carry the Allen key with me when sailing on longer excursions.
Your pre-sail check should include inspecting under the boat before you get underway. I speak from experience. Almost went flying early in my Bravo sailing in a good swell when the port side hiking strap gave out. (This was very exciting...) Suspect it was not correctly treaded when originally set-up.
PostPosted: Mon May 21, 2012 6:48 pm
According to the previous owner, my boat was assembled by the dealer. I know the dealer, and I've never heard of them selling an unassembled boat. There was nothing on the bolts to indicate that the loctite, had been used on them.
I'll definitely loctite them now, but I'm not sure if, because of the simplicity of this boat that maybe the dealer put a junior staff member on the assembly of this boat.
Either way, I agree that it's a good idea to inspect these bolts. There's no excuse for me not to have done so sooner. Hopefully someone else can learn from this before they have a problem.
PostPosted: Mon Jun 17, 2019 3:56 pm
ahhh, read this too late! On a gusty day my entire a-frame was ripped out.
PostPosted: Mon Mar 22, 2021 8:01 pm
Just want to add my +1 to this, definitely worth checking your a-frame bolts. Ours were very loose on our (new to us) second hand bravo, fortunately we'd only been out in gentle conditions before I noticed it.
In fact, it's possibly worth tightening them from time to time, which means removing the cover plate, just to keep the screw on the cover plate from seizing. Ironically, the hardest part here was getting the cover plate screws free, so as to get to the loose bolts underneath...
PostPosted: Thu Oct 19, 2023 7:22 pm
For me, they move the bar moves up and down when sailing.
PostPosted: Thu Oct 26, 2023 9:31 am
Thank you for sharing your experience and the valuable reminder to check the hidden bolts on the Bravo tripod. It's important to ensure the safety and integrity of your equipment, especially while sailing. Twitter Impressions Useviral
Your account of the situation will undoubtedly help other Bravo owners prevent a similar issue. Safety first, and it's always good to learn from experiences like this. Thanks for the heads-up!
Kyle
PostPosted: Thu Oct 26, 2023 9:32 am
Thank you for sharing your experience and the valuable reminder to check the hidden bolts on the Bravo tripod. It's important to ensure the safety and integrity of your equipment, especially while sailing. Your account of the situation will undoubtedly help other Bravo owners prevent a similar issue. Safety first, and it's always good to learn from experiences like this. Thanks for the heads-up!
PostPosted: Wed Dec 06, 2023 1:04 pm
HarryPotter69 wrote:
there are also 2 nuts on the side I wonder they are replaceable and thanks for sharing your expertise
Under the A frame where the two bolts go in? Those are molded-in to the plastic and not replaceable.
