It is currently Sat Apr 27, 2024 9:54 pm
 Post subject: rightening
PostPosted: Thu Apr 15, 2021 7:24 am
All,
It seems that I always need 420 pounds to righten the getaway.... which means I can't sail the getaway alone (I am 190lb)... not even with my 150 lb son, nor with my 110 lb daughter... We end up always needing to be 3+ people?
I see a lot of Hobie 16 videos on the bag system, but none on getaway.
Does anyone have a proven system to righten getaway solo with a bag system? Where do you hook the bag? What is the minimum weight you need to righten the getaway?
thank you,
Paolo
 Post subject: Re: rightening
PostPosted: Thu Apr 15, 2021 12:07 pm
Take a look at this: https://www.hobie.com/forums/viewtopic.php?f=23&t=60438&hilit=righting+board
Below is a video of righting a Getaway solo using the righting pole. There are also some details about building the pole further down in the above series of posts.
https://youtu.be/eHvCGd8DkD0
PostPosted: Thu Apr 15, 2021 6:13 pm
Shroud Extenders. I have them on my 21SC and can easily right the boat with 320lbs.
PostPosted: Sat Apr 17, 2021 2:47 am
I use a righting bag from Murrays https://www.murrays.com/product/01-3280/
Hobie Tandem Island "Sold"
WETA Trimaran "Sold"
Hobie Getaway
PostPosted: Sun Apr 18, 2021 10:59 am
PostPosted: Sun Apr 18, 2021 1:43 pm
Have the mast at a 45 degree angle into the wind with the wind hitting the front of the mast. Even a very light wind will get under the sail. Practice in a out of the way area. You will get dialed in.
With 1 kid will be easy, by your self should work ok as long as you have the mast positioned good.
PostPosted: Mon Apr 19, 2021 6:44 am
Anyone willing to share a video of rightening a getaway with a bag?
PostPosted: Mon Apr 19, 2021 9:46 am
I don't understand. I'm 200# and can right the boat myself. I once capsized with my wife, and she did most of the work herself, I don't think I loaded more than 50# on the righting line. And she's pretty little.
I use the supplied righting line, no righting pole.
Yet another Bob!
Too many canoes and kayaks
PostPosted: Mon Apr 19, 2021 6:42 pm
https://lh3.googleusercontent.com/ztLJo ... authuser=1
Don't have a video but I'm 190 #, as as long as I have the mast into the wind so the wind gets under the sail it's pretty easy.
https://lh3.googleusercontent.com/hD8j_ ... authuser=1
PostPosted: Tue Apr 20, 2021 12:45 pm
Not a Getaway, but same idea...
https://www.youtube.com/watch?v=1UyUZOP94-8&t=340s
PostPosted: Sun Apr 25, 2021 5:03 pm
I tie it to the mast base stud. The bag is strapped on the front tramp, when capsized, I throw it over the hull in the air.
Hobie Getaway
