It is currently Sun Apr 28, 2024 6:03 pm
 Post subject: Lynx durability
PostPosted: Thu Jun 03, 2021 7:37 am
I recently purchased a Lynx and have been loving it so far. What is the durability like compared to a Pro Angler? Is it easy to crack? Should I be worried about any scratches or gouges?
 Post subject: Re: Lynx durability
PostPosted: Thu Jun 03, 2021 3:58 pm
The Lynx is more fragile than a rotomolded product. If you puncture the skin, you need to repair it before getting back in the water and the internal foam core could take up water.
Treat like a glass surfboard or SUP.
PostPosted: Fri Jun 04, 2021 9:04 am
That's where I'm fishing most of time.
There are a lot of these "limestone tables" made by a marine worm. They can be just underneath water.
So for me the Lynx don't seem appropriate Matt, no?
François - French Hobie fishing team - Outback 2019 papaya
ex: Revo 13 2007 - PA 14 2008 - PA 12 2009 - Outback 2011/2013/2015 - Compass 2017
PostPosted: Fri Jun 04, 2021 10:17 am
I would go with a rotomolded boat.
PostPosted: Mon Jun 07, 2021 6:45 am
Thanks for the response.
Do you think it would be possible to install a keel guard? If there ever were any hull damage, are there any recommended epoxies to repair it?
PostPosted: Tue Jun 08, 2021 10:46 pm
Just see it's polystyrene foam. Can't take up water as it's bubbles no? Matt?
PostPosted: Wed Jun 09, 2021 5:18 pm
They say it can in gaps. Not the pellets themselves.
PostPosted: Wed Jul 21, 2021 10:31 am
Has anybody used these around oyster bars? I currently have a rotomolded kayak and have a lot of scrapes on the bottom from years of use inshore in the sarasota area. Will the lynx hold up to this type of environment?
PostPosted: Wed Jul 21, 2021 11:05 am
No. It is more like a surfboard or SUP...
PostPosted: Thu Aug 12, 2021 8:55 am
I found these instructions for repairing Bic Ace-Tec SUPs by filling gouges with epoxy. It looks pretty straightforward and I assume it would work on the Lynx as well.
https://media.taheoutdoors.com/s/aEoBMGqeRYAGRHA
I'm also going to put these PVC strips on the problem areas. My local river is rocky and no matter how careful I am damage is going to happen!
https://www.keeleazy.com/
PostPosted: Fri Aug 13, 2021 2:34 am
I am also concerned about the durability of the Lynx. I fish the Susquehanna and it has some rocky areas. Should I consider another kayak and skip the Lynx?
PostPosted: Fri Aug 13, 2021 9:06 am
If you are banging on rocks? Yes.
PostPosted: Fri Aug 13, 2021 9:42 am
Not so much banging off rocks but I do bottom out and get hung up sometimes.
PostPosted: Thu Nov 18, 2021 3:25 pm
I got the KealEazy PVC strips applied to my Lynx. Here are some pictures. I used it half a dozen times unprotected and then put the strips on the places I was starting to see a rash. The keel is obvious for normal wear and tear, but I was surprised to see it on the chines. I think this happened in the bed of my truck.
The strips seem well-bonded but I've only used it once since, so we'll see how it holds up next season. In the last picture you can see one spot where I held the heat gun a little too long and the hull started to bubble. Be careful if you do this yourself!
PostPosted: Fri Apr 08, 2022 9:23 pm
I have a small puncture on the bottom of my Lynx. What should I use to repair it?
