It is currently Fri Apr 26, 2024 9:21 pm
 Post subject: Dent in hull
PostPosted: Thu Aug 26, 2021 4:44 am
I have a Wave and considering buying a Bravo. I was all good with buying it until the seller told me that the Bravo has been sitting against a trailer fender and it has left a dent in one of the hulls. The Bravo is located in SE USA and has been sitting in the heat I assume. The seller is confident that they dent will come out naturally over time, is that true?
 Post subject: Re: Dent in hull
PostPosted: Thu Aug 26, 2021 8:11 am
It might...
https://www.hobie.com/forums/viewtopic.php?f=21&t=35313
PostPosted: Thu Aug 26, 2021 8:32 am
Hi Matt:
I am not sure the thickness of a Bravo's hull compared to that kayak in the video but I am assuming the Bravo is thicker? Is that rotomold of the kayak the same type of rotomold as the Bravo? I guess you using the word "might" should scare me. Thanks for your time.
PostPosted: Thu Aug 26, 2021 8:53 am
Maybe a little thicker. Same material and process as a Kayak.
