It is currently Sun Jun 16, 2024 2:44 pm
PostPosted: Thu Aug 26, 2021 6:40 pm
I am going to attempt to improve my ti’s ability to tack into the wind by attaching skegs to it amas. What kind of adhesive should I use to attach plastic skegs to the amas?
PostPosted: Fri Aug 27, 2021 9:24 am
DP8010 maybe?
PostPosted: Sat Aug 28, 2021 2:43 pm
3M’s DP8010 does not seem to be available. How about JD Plastic weld? Are they equivalent?
Are you aware of anyone trying to do this?
PostPosted: Sat Aug 28, 2021 3:03 pm
There are other Dupont products that work with Polyethylene.
No, don't know of anyone adding skegs. Seems it would make beaching more difficult?
PostPosted: Sat Aug 28, 2021 5:01 pm
He’s not as active on the forums as he once was but send a PM to fusioneng who is quite knowledgable on this topic.
Peter
PostPosted: Sat Aug 28, 2021 7:47 pm
Interesting idea.
Four years ago I fitted skegs to my Adventure hull to assist paddling in strong crosswinds using VHB tape and they are still holding strong. Worked so well I fitted them to my Oasis to stop fishtailing when towing it behind a boat.
If the hull is properly prepared by flaming and alcohol cleaning and you have enough surface area contact, VHB tape can be considered a permanent bonding solution to PE for many accessories.
More info- https://www.hobie.com/forums/viewtopic.php?f=11&t=60698
