It is currently Mon Apr 29, 2024 9:57 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 15, 2018 8:23 pm
Sorry 'nap' but the fact the Lock Bearing is held in place with 6/32 screws should indicate they're not made to be torque'd down.....
It would not make any difference if the the Lock Bearing was plastic or SST, they're 'just' 6/32 screws.
PostPosted: Fri Mar 16, 2018 5:06 am
Understood. Thanks.
I think this lock bearing is poorly design. Sorry Hobie.
Ill just put a drop of sikaflex on the new one to strengthen that part with small crack. And include in my maintenance checklist. I purchased 2 as backup and will keep the old ones. And continue to use the keep out line as I feel this lock bearing will eventually break and cause the akas to come out.
For those installing it, look closely where the screw head will sit and youll see that pushing the screw head down more than it supposed to will also push the plastic down. I have a poor vision and installed it outside with not much lighting which contributed to not making good judgement.
PostPosted: Mon Apr 16, 2018 4:32 am
mmiller wrote:
christian.herve. wrote:
Can you tell me if m’y TI is concerned ? Do I have to change those parts or not ? If yes, how can I proceed ?
https://www.hobie.com/forums/viewtopic.php?f=71&t=61653
mmiller wrote:
Free Island Updates Announced To Dealers Today
We have received enough parts to start offering an AKA Lock update. We have also created a furling line guide that helps to prevent the line from getting stuck around the bearing plate. Both kits are available through warranty at no charge.
79520604 AKA LOCK KIT HINGED HOOK
This kit includes 4 sets of aka spring hooks and the aka bearings they lock to. This creates a more positive lock for the aka into the crossbar that is less affected by part distortion or aka twisting motions. This is standard on all new Islands. Instructions: https://static.hobiecat.com/item_attachments/79520604.pdf
79512101 ISLAND FURLER LINE GUIDE KIT
Keeps the furling line from getting stuck on the bearing plate. Guides the line up onto the drum when you pull on the furling line. This is standard with all new Islands. Instructions: https://static.hobiecat.com/item_attachments/79512101.pdf
Contact your dealer to receive these updates.
My dealer said these are no free upgrades.....Is it just a certain area that free upgrades are available?
Rob From NJ
https://www.youtube.com/channel/UC5KKul ... subscriber
PostPosted: Tue Apr 17, 2018 5:10 am
If Hobie says they're free, the dealer needs to comply...
PostPosted: Tue Apr 17, 2018 9:14 am
Always free. Everywhere.
Have them refer to their Dealer bulletin we posted 10-6-2017.
PostPosted: Sun Aug 11, 2019 1:00 am
Now I have finally got these free upgrades - THANK YOU!
But still would appreciate if anyone could post a picture.
It is not possible to mount this furling guide as shown in the pdf file.
best regards
thomas
PostPosted: Sun Aug 18, 2019 1:17 am
best regards
thomas
How is it not possible? Don't the holes line up on the underside of the bearing housing? I only say this because I don't recall anything remarkable when I fitted it to my TI.
PostPosted: Mon Aug 19, 2019 3:23 am
Please Tony, post a picture!
A close up.
br thomas
PostPosted: Fri Jan 01, 2021 3:41 am
best regards
thomas
My old mate Pirate installed his yesterday after we had a discussion about the furling line guide.
The only way it made any sense was to disregard the totally misleading instructions and work it out applying logic!
It makes absolutely no sense to install it under - so he installed it above!
Its a bit fiddly because there are non captured nuts that will drop into the mast well if you aren't careful.
I know he took photos but I dont have a copy yet.
I expect i will in a day or so.
Perhaps this bit of info will be enough for you to figure it out.
it is truly amazing that no one has posted photos of the installation after all this time!
Mickey
2016 AI Hibiscus
PostPosted: Fri Nov 12, 2021 6:12 pm
best regards
thomas
I must admit, this one has me puzzled. I have the Gide installed just as the instructions show but I do not see how it does anything at all. I’m usually pretty good at visual-spatial perception but on this one. They say it works and I haven’t experienced a jam yet so, I’ll just consider it magic.
-Mark
PostPosted: Fri Nov 12, 2021 9:30 pm
best regards
thomas
I found this post here… it’s an earlier model but installed pictures are correct. https://www.hobie.com/forums/viewtopic.php?f=75&t=62457
PostPosted: Fri Nov 12, 2021 9:53 pm
best regards
thomas
Good find maxwellmark.
It fits as per the instructions on 2015+ model AIs - but requires modification to fit earlier boats.
No one I know has ever actually experienced the issue that this upgrade was designed to rectify.
I ended up removing it from my 2016 Dune AI when I had to replace the top & bottom mast receiver ball bearing plates due to my 24 plastic balls falling out.
Mickey
2016 AI Hibiscus
