Joined: Fri Jul 13, 2018 9:01 am Posts: 152 Location: Near Austin, TX
Hi gang,
Okay first, Hobie has helped with direct communications where in the first obvious issue here is that I have the accessory furling ling guide installed wrong, it's not supposed to be on the top bearing plate, it should be on the bottom plate (upside down), so I will need to look into that. Second is the issue where my 2013 mast foot seems to be a tad shorter from the furler to the foot, resulting in a bit of friction w/o the furling guide and a TON of friction with the incorrectly installed furling guide. So I will either install the furling line guide correctly or just do away with them all-together since I really never had issues with furling anyway. But, I'd like to address the 2013 so that is doesn't rub on the lower furling plate and the upper boat-side plate. Hobie suggests I could adjust the V-frame by tightening the turnbuckles which would draw the mast upwards and make more clearance between the mast and bearing plate. But I just don't see how that would be so? I also am a bit concerned about trying to adjust this V-frame as it's probably pretty set with its age.
Notice how on the 2009 AI mast foot, the extreme lower foot/cap has a smear of epoxy. I didn't' put that epoxy there and I'm unsure if that is factory stock like that? Or, maybe a previous owner drilled out the original rivets and shifted that cap downward a bit and drilled new holes, new rivets and added epoxy? Is this a possible cure to the 2013, would you do this?
Just looking for advice in concert with Hobie's advice which I am not questioning so much as just seeing if anyone else has done anything different? Here's the video:
Joined: Fri Jan 05, 2007 9:21 pm Posts: 2499 Location: Central Florida
In the pre-2015 AI's, the shape, and therefor the height of the bow can be adjusted with the 2 turn-buckles in the front hatch. Be careful to try to adjust so the spool is just clearing the bow or the reefing line tends to jam between them.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum
