It is currently Wed Jun 05, 2024 7:42 am
PostPosted: Sun Sep 18, 2022 8:28 pm
I considering a TI but not sure I can store it properly. I have 2 Hobies in my garage now and there is just not room for another (small 2 car garage). My driveway extends to the side of the garage and I have considering extending the garage via a lean to and wondering if anyone does the same? How do you store your TI? Can you store it on a trailer without damage?
Thanks...
22 Lynx
22 Compass Duo "Liparus"
22 TI "Victoria"
PostPosted: Mon Sep 19, 2022 9:17 am
A TI can be stored on a trailer as long as it has a decent bed that doesn't cause any hull deformations. Just cover it with a tarp to keep the UV off and you should be fine.
I keep my TI on its trailer for the entire boating season. Off-season, I store it suspended from a carport ceiling. I've been doing this since 2015 with no issues and it still looks and works great.
PostPosted: Mon Sep 19, 2022 3:20 pm
I store TI on the trailer and in my garage. Works great considering all the tinkering with this kayak.
Jim
Hobie TI 2022 - Offshore rig - Outboard - having fun!
Hobie TI 2021 - Offshore rig - Outboard - sold
Hobie TI 2016 - Offshore rig - Outboard - sold
Hobie Kona 2014
Hobie AI 2015 - sold
Hobie Rev 13 2014 - sold
Hobie Outback - 2008 - sold
PostPosted: Mon Sep 19, 2022 9:15 pm
Thanks guys for the replies. One more ?: How are your trailers setup as far as bunks go. Do you use those hobie cradles?
Thanks..
22 Lynx
22 TI "Victoria"
PostPosted: Tue Sep 20, 2022 6:18 am
Thanks..
I started off with the Hobie cradles but they soon cracked.
So then I went with PVC pipes, but they cracked too, although they lasted years longer than the cradles. Plastic is not a great material for trailering. Too much vibration from the road. Plastic can only take so much flexing before it cracks. Something better is needed.
Just before the next boating season, I'm going to revamp my trailer bed with something more durable than plastic. I'm looking into wood or metal.
PostPosted: Tue Sep 20, 2022 7:43 am
I made wooden cradles for my TI garage hoist, which is how it is stored during the winter months.
I just replicated the shape (as closely as I could) of the Hobie cradles on my trailer.
If I were to use my wooden cradles for the trailer, I would just cover them in a carpet or something, to make sliding on & off easier.
PostPosted: Tue Sep 20, 2022 9:41 am
I have an Oasis on my trailer, not a TI. But I made bunks 5 years ago using two gray 2" x 10' schedule 80 conduit PVC and they still look brand new. Unlike regular PVC, they are thicker and have UV protection. On the Oasis this PVC size does not contact the reinforcing scupper inserts. My kayak is on the trailer year-round. Note PVC is measured by inside diameter and these are actually 2 3/8" outside diameter.
Peter
2016 Hobie Oasis with Evolve v2 rudder mount, Sidekick ama kit, Mirage sail kit, Garmin echoMAP CHIRP 42dv, bilge pump
2007 Hobie Outfitter x 2 with Mirage sail kits, large rudder blades
PostPosted: Tue Sep 20, 2022 5:23 pm
Peter
Thanks - will give this method a try when the time comes.....
22 Lynx
22 TI "Victoria"
pro10is wrote:
Thanks..
I wonder if you could make that stronger by filling in the back with a wood/epoxy mixture?
22 Lynx
22 TI "Victoria"
PostPosted: Thu Sep 22, 2022 5:25 am
I had the same issues with the Hobie cradles. Just too fragile for frequent routine use.
I moved to a simpler set up. Strong and durable for frequent use
See this post for photos and a bit more information.
https://www.hobie.com/forums/viewtopic. ... 10#p334390
Jim
Hobie Kona 2014
PostPosted: Sat Sep 24, 2022 6:23 am
You would need to ensure that all flexing is eliminated, otherwise, the cradles will eventually crack.
The cradles are fine for storage, they're just not good where any flexing occurs such as with trailering.
PostPosted: Sat Sep 24, 2022 11:38 am
I have it in the ceiling of my garage.
