It is currently Fri Apr 26, 2024 2:23 pm
 Post subject: Gennaker lubrification
PostPosted: Wed Jul 04, 2007 3:50 am
Hello, could anybody suggest me a product (teflon based?) to lubrificate my gennaker?
I set the soft hobie sock and the hard mouth on my Tiger and I am in trouble everytime I have to drop this sail down.
I also need to know the best way to use it.
Thank you.
COME SAILING IN TAORMINA!
PostPosted: Wed Jul 04, 2007 4:24 am
HOLMENKOL - Seal'n'Glide
Directions come with it.
PostPosted: Wed Jul 04, 2007 7:13 am
This is good stuff too. Our sail loft has used this stuff by the gallon when installing in-mast/in-boom furling mains. McLube Sailkote.
Brian C
PostPosted: Wed Jul 04, 2007 8:43 am
I have used the Holmenkol on my spinnaker and like it very much. I use the McLube locally on the main luff but it does not last as long, I think.
The Holmenkol is a two part system that you have to sponge on or dip in a bucket to apply. You do not spray it on! You get about 90 minutes to apply it. One application takes care of two F18 spinnakers but you can use it 1/2 at a time with careful measuring. Best is to split the cost with a friend and do both chutes at the same time.
Later,
Dan
PostPosted: Wed Jul 04, 2007 9:50 am
Thank you for lightspeed replies, I've yet used mc lube spray for the main sail and I think it's very useful (I can hoist this sail without any effort).
How often do I have to lubrificate the gennaker, how can I see when it's time to do it?
Bye, mattvin :D
PostPosted: Wed Jul 04, 2007 10:19 am
You're somewhat correct about the aerosol Sailkote. Sailkote can also be bought in a non-aerosol form (also pretty much applied with a mop). In that form, it lasts a long time. The Homenkol may be more available in Italy. I did not find an Italian source for Sailkote.
Brian
PostPosted: Tue Jul 24, 2007 1:48 am
Hi, just yesterday I sponged my gennaker with HOLMENKOL - Seal'n'Glide and I am very satisfied.
Thank you everybody :D
PostPosted: Tue Aug 07, 2007 6:22 am
So.... It sounds like you apply this to the whole sail, and the sock? I wouldn't have guessed this.
PostPosted: Tue Aug 07, 2007 9:18 am
Whole sail yes, sock optionally.
