It is currently Tue May 07, 2024 2:58 pm
 Post subject: Creaking tramp frame
PostPosted: Sun Aug 12, 2007 5:27 pm
Hi all. My tramp frame creaks a lot and is pretty noisy. It comes from where the side rails go into the corner fittings. I have tightened the tramp lacing which helped a bit but still creaks. Is this normal for a newer H16? I do not remember my 81 making noise. Does anybody else have a creaky boat?
07 H16
Sail No. 110387
PostPosted: Sun Aug 12, 2007 5:57 pm
My last new 16 creaked for ten years.
PostPosted: Mon Aug 13, 2007 11:16 am
I get a fair amount of creaking on my 16 too, although am not sure where it is coming from- tramp frame to corner castings, corner castings to pylons, dolphin striker to corner castings, or pylons to hull (deck and hull socket.) The noise is coming from the front corners (where the most stress is from the mast and sails.)
So far I have replaced all the nylon nuts with SS nylocks, so will carefully tighten those and the dolphin striker nuts. I was also thinking of removing and replacing all the rivets. I figured it couldn't hurt and I really don't want to try the epoxy pylon method.
Any thoughts?
PostPosted: Mon Aug 13, 2007 11:36 am
Any thoughts?
Over-tightening the pylon bolts will get you nothing but broken castings.
Same with the dolphin striker. It should be only tight enough to go "thummmmm" when you hit it with your hand (it goes "thunk" when it's not tight enough).
Replacing the rivets will work - for a while. But that's just one joint of three that's creaky.
You could shim the pylons if you don't want to glue the boat. That will help for a while, too.
The only way to truly cure a creaky boat is to glue it.
PostPosted: Mon Aug 13, 2007 11:40 am
MBounds wrote:
Any thoughts?
I've been careful about not over torquing and cracking the castings. It sure would be nice to know where the sound is coming from, however.
PostPosted: Mon Aug 13, 2007 12:42 pm
Authorized Hobie Dealer
I went thru 6 new h16's trying to find one for myself that didn't creak . it came in 2004 worlds boat, it may have squeaked when new but by the time it arrived in at the shop it was quiet as a mouse! Just keep sailing it should get quiet
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Tue Aug 14, 2007 12:30 pm
I have an 83H16 and the thing has creaked for years. I've just put up with it. What do you mean by glueing the boat?? I would like mine to stop too. I have checked all bolts and rivets and they are all tight and in good shape......hhmmm
'83 H16 Tequilla Sunrise and Cat Fever
PostPosted: Wed Aug 15, 2007 10:01 am
Thanks for the replies. I will contimue to sail it! Actually I do not notice it much on the very windy days but on the lighter to moderate wind days (which is when wife is crew) its pretty noticable. I was also told by the local dealer that it will subside with time. I have had the boat out 25 times so far this year and still noisy but this is a very small annoyance as the boat is performing very well and I am completely happy with it. Thanks again all.
07 H16
Sail No. 110387
PostPosted: Wed Aug 15, 2007 12:04 pm
How is the sailing up in Coeur d'Alene?
Does that deep water stay cool into the summer? My sister camps and boats there on occasion. I've flown over it many times in years past (courtesy of the USN) but have never been there on the ground.
PostPosted: Wed Aug 15, 2007 6:35 pm
My 2006 boat is also very creaky.I have been told that means it is stiff.I also read once that Enrique Figurioa (world class 16 sailor) likes his boats to be creaky,means they are stiff and fast. Also remember with my older boat the more I shimed it and tighened the tramp the noisier it got.Some guys put some marine grease on the pylons when assembling it.
PostPosted: Wed Aug 15, 2007 7:09 pm
that must mean that I have a fast boat. the tramp is tight. and they are predicting wind for friday in atlanta so hopefully i get to put her in the water. :lol:
