It is currently Tue Aug 04, 2026 3:31 am
PostPosted: Sun Jul 01, 2018 8:01 pm
Dont forget when paddling you can always put a fill plug in your drive plug and fill it with ballast to help keep COG lower. I just use water so I can fill it at waters edge, but you could use something heavier if you like. I use the taller plug in the revo 16 so it holds more, gives an up stand, rather than flush to hull, providing heel bracing and also a raised dry surface to rest stuff on, rather than just a big puddle in the footwell.
Good idea to make up some more substantial foot rests rather than trying to grip the scalloped hull sides. I bolted on some plastic door wedges at the appropriate spot.
PostPosted: Sun Jul 01, 2018 10:10 pm
This drivewell plug weighs 24 lbs, filled with lead shot and a binder -- adds significantly to stability, No protrusions.
Add a flush bottom...
...and you have eliminated any drivewell drag.
The only problem is, it doesn't lighten the nose.8)
PostPosted: Mon Jul 02, 2018 2:03 am
That trim plate is on my to do list as I already have the necessary matching plastic on hand
