It is currently Tue Aug 04, 2026 11:54 am
PostPosted: Tue Aug 05, 2008 12:42 pm
Anyone know if it's possible to slide half a standard paddle into the Oasis hull? And, has anyone used the mini kayak cart? Are there any other cart options that will fit through an 8" hatch? ...thanks
Frank
PostPosted: Wed Aug 06, 2008 10:11 pm
Hi Frank and welcome to the forum. The standard paddle will not fit through any of the three Oasis hatches, but Hobie sells a 4 piece paddle that should fit in at least 2 of the hatches. Or, you could possibly cut a paddle down if you don't like the standard paddle mounts.
Check out Stringy's posts for storing the cart upside down in the nose of the front cockpit or consider a couple of padeyes and bungee it on the foredeck if you can't use the aft cargo well.
If there's a will, .... 8)
PostPosted: Thu Aug 07, 2008 12:59 pm
Thanks for the paddle info, I'll get a telescoping one then. I will be storing the boat at a marina and the more I can store in the hull, the less to haul there and back, especially when I bike.
PostPosted: Mon Aug 25, 2008 6:05 pm
I have the older plugin cart and usually just store it in the back of my Outback using the standared bungy "net". But as I looked at it one day I relized that the golf cart wheels have a simple set screw arangement where one simply unscrews and removes the wheels. I also found that with the wheels removed, I can just barely fit the metal frame into the front hatch and dump the wheels in as well. But since I don't use the rear area much, I just store it there most times.
thomas
Absolute kayaking corrupts absolutely.
PostPosted: Wed Aug 27, 2008 2:51 pm
That's good to know. I'll check out the newer cart next time I'm at a dealer.
