It is currently Tue Aug 04, 2026 7:08 am
 Post subject: Mirage clip
PostPosted: Thu Jan 01, 2015 7:37 pm
Hi does anybody know what year did Hobie change there clip that holds the drive system. And is there any pictures of the old style and new style. i'm going to look at one this weekend and the seller doesn't know what year it is.
 Post subject: Re: Mirage clip
PostPosted: Fri Jan 02, 2015 11:52 am
Not 100%, however I want to say the newer click & go was 2011. (pretty sure)
PostPosted: Fri Jan 02, 2015 11:54 am
Older:
Cam lock knobs are black with a bolt down the middle.
Newer:
The click and go are stainless with a black housing and lever ends.
PostPosted: Fri Jan 02, 2015 12:57 pm
Our old Oasis and our old revo's were all 2007-2008 vintage, and they had the old style clips (worked just fine with no issues. Our first TI was 2010 and that had the newer style clips (also work with no issues).
All Hobie kayak have a serial number engraved into the rear right corner of the hull which shows the month and year of manufacture.
If an older boat is in good condition and everything works and it doesn't leak (always inspect and check for leaks) then I would have no issues buying a used hobie mirage kayak.
Hope this helps
Bob
PostPosted: Fri Jan 02, 2015 2:12 pm
Thank you Guys for the info.... I'll check it out Saturday. If I get it I'll post pictures.
PostPosted: Sat Jan 03, 2015 9:46 pm
2009. The new style (Click N Go) is much more durable, especially if you're using Turbofins. 8)
