It is currently Tue Aug 04, 2026 4:48 am
PostPosted: Thu Jan 14, 2016 9:15 am
I am 65+ years old and my favorite fishing hole is quite a distance from the launch point. I am wondering if a MinnKota or Motorguide 30lb thrust (smallest that they make that I can find) will fit through the mirage drive slot. Has anyone tried this?
PostPosted: Thu Jan 14, 2016 1:31 pm
I have a Minnkotta on the back of my TI it is a 55lb thrust. This unit would not fit through the Mirage drive. However the Minnkota shaft is fairly easy to remove and if you did this you could push it through the drive and mount it. Since the engine is mounted on the bottom of the minnkotta I don't think the 30# thrust would fit directly through so you would have to remove and reassemble the shaft. You will also add 70-90lbs to your boat. The problem is it is too much work to do every outing so it would be there to stay which would probably cause trailering problems.
I would recommend a mount on the tail and a battery in the front to balance it off. Check your weight, electric gets heavy and expensive. You may want to consider a 30lb gas motor if you have a distance of over 5 miles. The minnkotta has been wonderful to have on the boat.
PostPosted: Thu Jan 14, 2016 7:58 pm
An 18 to 24 lb thrust motor will push the boat as fast as a 30, or a 55 for that matter. The pitch on most motor props can't take advantage of the additional thrust when pushing something as light as a kayak. All they'll do is drain your battery more quickly.
PostPosted: Thu Jan 21, 2016 6:37 am
Read my posts on DYI "through-the-mirage-hole" trolling setup.
$100 for Watersnake trolling motor (T18 or T14), about 7# of weight
~$200 for 40AH lithium battery + charger on Ebay, about 14#. Look for U1-12RT
PostPosted: Thu Jan 21, 2016 10:22 am
Those batteries look pretty cool, how did you adapt the connectors for the motor and for charging?
Sent from my iPad using Tapatalk
On the bank of the Bow River
