It is currently Sat Jun 20, 2026 12:34 pm
PostPosted: Sun Jul 26, 2009 9:14 am
Anyone have any tricks for removing std sideplates and upgrading to the bigger late model plates?I found a small hairline crack a 1/4" aft of my starboard plate that starts at the lip and goes down about 1 1/2". I plan on glassing the inner hull ,but it sure is tight in there.Anyone else run into this issue.I have to get it taken care of before Havamega in nov.
thanks Shawn
82 H18 #8211
Div.3
PostPosted: Sun Jul 26, 2009 10:21 am
Shawn,
I was not aware that there were two different sizes.
As far as repair hints, you might want to check with Jeremy @ Surf City Catamarans.
He is an incredible resource on every level.
Stephen
If the grass is greener on the other side of the fence, maybe it is time to water your own lawn.
PostPosted: Sun Jul 26, 2009 4:34 pm
hey Stephen,I am pretty sure there are two size plates,I am having Jeremy send me a set.I havent got into the hull yet.I am hoping that I dont have a problem getting the old fasteners loose.I plan on scuffing up the hull with 80 grit and laying some bi-directional glass inside and roll it out.I think i am going to have a problem if I cant get the repair area fairly flat inside because I still have to deal with the washers and nuts in that tight area.I can barely get a wrench on the existing nuts to tighten or loosen them.
shawn
PostPosted: Mon Jul 27, 2009 9:45 am
Hey Shawn lets see a pic!
Thanks for the kind words MUST. See you in Havasu for some of the same as the 40th.
J
PostPosted: Mon Jul 27, 2009 10:44 am
Shawn, before you start laying up glass on the inside seam area you might want to consider making some filler material to smooth out the 90 degree seam first. Try to get a curved radius, using the diameter of a quarter as a guide. You can make the filler using resin and colloidal silica. Try to avoid applying fiberglass & resin to a hard 90 degree angle. Use something curved like the backside of a spoon, or a flexible squeegee to get a nice radius curve in the material. Also, when you talk about the plates is what you have on there now shaped like "u" channel? The newer - retro- plates are the "stirrup" shaped.
PostPosted: Mon Jul 27, 2009 7:19 pm
Yea,Rick,They are the u-shaped plates with 4 stainless screws in an arch. The plate is almost tucked away in the recessed area of the hull. The bigger 4 bolt ones i have seen look like they not only come down the gunwale farther but are wider also.I left my boat up at whiskeytown lake for the week ,going back up next fri to sail again,I will get a few pictures.I really cant see how a hairline crack started there running verticle,hopefully that top joint between the deck and hull isnt letting go partially.I just dont want to see a hole where my anchorplate used to be and my mast laying in the water,ha ha ha .
thnx shawn
PostPosted: Tue Jul 28, 2009 7:13 pm
Just so there is no confusion,Jeremy shipped me the replacement plates and there is a huge difference in size.This should cure my problem for sure.There is definantly two different size plates on the h18.
thnx Jeremy for the quick shipment.
Shawn
PostPosted: Tue Jul 28, 2009 9:05 pm
You going to be at Whikkytown this weekend? I can run arround the hill and give ya a hand.
Rich Vilvens
F-18 5150
PostPosted: Tue Jul 28, 2009 9:42 pm
Post some pics of the difference when you get a chance if you would please.
J
PostPosted: Tue Jul 28, 2009 9:45 pm
J
Yeah, what Jeremy says, Pictures PLEASE, I've never seen but one size.
Stephen
PostPosted: Tue Jul 28, 2009 10:19 pm
Yeah .Rich I will be at whiskeytown friday and saturday,maybe sunday but im not going to try to glass this up till i get back home.Should be good wind 11-19 they say .
shawn
PostPosted: Tue Jul 28, 2009 10:35 pm
I may come up. Depends on a few things, but could make for a nice diversion from bieng stuck here in the house. I can't sail but I can get out im cleared to do that.
Rich Vilvens
F-18 5150
PostPosted: Mon Aug 10, 2009 8:12 pm
Got the job all done ,Thanks Again Jeremy at SURFCITY CATAMARANS,SANTA CRUZ CA.
A word of warning to anyone out there with a 81-82-83 h18 that has the small sidestay anchorpin plates,REPLACE THEM with the larger stirup style plates for front x-bar reinforcement.They use the same part.My boat has been babied and garaged most of its life before I got ahold of it and it still showed stress cracks on both sides of the boat.I think because the screw holes are so close together.Anyway I got her all kevlared up with 9 oz fab and west sys. epoxy. Thanks for all your input everyone, much appreciated!!!!!!!
Shawn (goin to havamega now!!!)
H18 #8211
Div.3
