It is currently Sun Jun 21, 2026 1:03 am
PostPosted: Mon Jul 26, 2010 8:14 am
i have 2 h18s side by side. just got an 82 and
want to swap some parts out with the older boat
1 pair is black anodized and has more to the casting
the others are not anodized- simpler design
which are the preferred ones to use?i understand i will need to do a bit of
change of placement of some of the hardware on the transom
also- i'm reading that the shroud pins are the major cause of dismasting.
are these on the boat or on the mast? easy to change out?
thanks for any input
Thanks,
P
peter myers
916 955-1148
PostPosted: Mon Jul 26, 2010 8:45 am
The pins are located at the base of the two sidestays and go through the hull lip and bracket. They are threaded and held on with a nut.
If you dont know the age of the pins you should replace them. There are a couple of very good posts on here describing the correct angle of the pin head as well as information about getting the correct improved pin.
Search "Demasting - Broken Shroud Annchor Pin" for a good thread.
1984 Hobie 18
