It is currently Mon Aug 03, 2026 12:04 pm
PostPosted: Thu Mar 12, 2015 2:53 pm
Hi There
I am trying to work out the exact age of my H18 as its my first hobie cat im a bit new to all this
It dosnt quite fit into the formula on the hobie serial website.
On Top RHS of transom CCMP15194 is engraved then underneath in the middle of transom 393 is there inside a rectangle with raised letters (look like label maker style letters). Obviously been put into the mould.
I tried to attach pictures but cant work out how to attach.
Sail number is 15195. Has a small clear panel with "hobie 18" at the bottom. Sail is all white
It would seem its a 93 or 94 maybe.
Rudders are after 86 I think
Would appreciate any help.
Gene
PostPosted: Thu Mar 12, 2015 4:05 pm
The raised numbers are a mold mark. The serial number is incomplete.
The Hobie 18 used CCMC in its later years. CCMP is not shown as used for a Hobie 18.
H16 P
H20 P
Image posting FAQ:
http://www.hobiecat.com/forums/viewtopic.php?f=18&t=8574
PostPosted: Thu Mar 12, 2015 4:10 pm
Ahhh... you are in Australia (looked at your IP)? Could have been a AUS build boat I suppose, but I think Bashford used a different serial sequence maybe?
PostPosted: Thu Mar 12, 2015 4:14 pm
Ahhh. I see.
Did bashford use the same year model codes?
PostPosted: Thu Mar 12, 2015 4:21 pm
Just to add - yep im in australia so good chance its an oz built boat.
Any aussie s familiar with this seial number?
