It is currently Mon Aug 03, 2026 9:12 am
PostPosted: Thu Sep 27, 2007 7:41 pm
One of my turnbuckles is cracked. Can I sail safely a few more times this fall and replace it before next year? Can water freeze and crack one? Your help is much appreciated. I have used a lot of your previous posts in rebuilding my 1982. THANKS!!
 Post subject: H18 Turnbuckle
PostPosted: Fri Sep 28, 2007 8:20 am
Assuming you are referring to the diamond wire turnbuckle.
Cat masts are tall and thin. They often need extra support. The diamond wires are there to prevent (sideways) bending of the mast, which could result in the mast snapping. The adjustment of the turnbuckles allow for more or less bend in the mast, that is, a flatter or fuller mainsail. Lots of debate on this one, BTW.
If a turnbuckle were to let go, sheet out the main to release any excess strain, and only sail on that tack where the wind is blowing on the same side as the 'good' turnbuckle. Figured out how to sail backwards yet?
So, for the price of a few bucks and a visit to your friendly Hobie dealer, do yourself a favour, and sail safe. Another winter maintenance project?
2015 H16, with spin,
PostPosted: Fri Sep 28, 2007 9:30 am
if you sail on a broken turnbuckle you are risking the main , mast and alot of other expensive parts . I am speeking from expierience replace them and be safe
Rich Vilvens
F-18 5150
PostPosted: Fri Sep 28, 2007 9:36 am
You can buy a replacement turnbuckle for less than $20 at West Marine. Not a bad insurance policy.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Sat Sep 29, 2007 6:21 am
Used mast $200 if you can find one. Sail repair $100. Risk of injury ?????
New Turnbuckle $20 - $30
Do the math..........
I wouldn't risk it. ever.
1989 Hobie 18 Worlds Boat, Magnum Wings & Spinnaker
1987 Hobie Holder 20 #273
dale.vanlopik"at"att"dot"net
