It is currently Fri Jun 19, 2026 3:08 pm
PostPosted: Fri May 21, 2010 3:15 am
I have a cherry 1977 H-16 with a good trailer. However, the trailer only has 4 rollers (each side, fore and aft) which the hulls then rest upon. When I stand on the tramp, while on the trailer, and raise the mast, I sometimes worry about the amount of weight I'm putting on those four points. They are the traditional hard rubber rollers. Am I being crazy? I've seen trailers that have semi-articulating black rubber rollers that are working in tandem. They load-up in pairs so the overall load is displayed by 8 wheels instead of the traditional four. I have no visible distortion of the hull, but I'm still concerned. I know the asymmetric hull works best with rollers, not cradles like the Tiger or H-18.
Anyone else ever seen these tandem roller set ups that actually 'teeter' or rock back and forth?
Thanks fellow flyers, bones.
PostPosted: Fri May 21, 2010 3:58 am
The four rubber rollers are perfectly fine for a Hobie 16.
The tandem rollers are overkill. They're more for a boat with round bottoms, like a 17, 18 20 or Tiger.
PostPosted: Fri May 21, 2010 8:46 am
I worry about it as well especially because to make mine fit in the garage the entire hobie actually sits on only 2 rollers because it's so far forward on the trailer.
PostPosted: Fri May 21, 2010 9:23 am
The keel is strong, it can take it
1981 Hobie 16
1982 Hobie 14 turbo (sold)
1996 SeaDoo GTI
1999 Hunter 340
