It is currently Sun Aug 02, 2026 8:00 pm
PostPosted: Tue Jul 10, 2007 6:48 pm
My old 1983 has carpet glued to the sidebar that needs to be replaced. Any thoughts on the best way to remove it?
Raced extensively as a kid (against Matt Bounds!!), just bought a 20 year old 16 and am refurbishing it.
Sail # 21888
PostPosted: Tue Jul 10, 2007 6:51 pm
A little chemical solvent and a putty knife
If that's not fast enough...sandpaper, you are going to cover it back with new, right?
HCANA Class Member
PostPosted: Tue Jul 10, 2007 6:55 pm
Yes, I'll be covering it back up w/ either carpet or neoprene. Which do you recommend?
Sail # 21888
PostPosted: Tue Jul 10, 2007 7:04 pm
Oops! works well on just about everything.
PostPosted: Tue Jul 10, 2007 8:00 pm
I just tore off all of my old anti-slip from the rails of my '81 of which I'm restoring. (Looks like were in the same boat!....sorry, couldn't resist the pun) I then pressure washed the rails real good. most of the old stuff shot right off except a smooth thin black layer of old glue. I've been debating on sanding and chemicals to remove the old glue but at the same time thinking if that old glue needs so much work to remove why not just re-glue on top of it?
I bought the H-16 neoprene rail kit (Page 11 in the '07-'08 Hobie catalog) for my '81. Price $48.00 plus S&H. I ordered that along with $250 in other things from Backyard Boats in Woodbridge VA. I placed the order with them last THURSDAY and it was at my door on FRIDAY. INCREDIBLE!!!
1981 H16.
1993 Macgregor 26S
PostPosted: Tue Jul 10, 2007 11:48 pm
I ripped off what I could, then used a putty knife with acetone to get the residual crud off. What the knife and acetone didn't get I sanded with an orbital sander to a smooth(er) surface.
I like Hobie's neoprene kit over the rail rug. Read this thread for more opinions:
http://www.hobiecat.com/community/viewt ... t=neoprene
