It is currently Fri Jun 19, 2026 4:39 pm
PostPosted: Fri Sep 04, 2009 3:26 pm
I bought a used '82 Hobie 16, I previously had a '74 H-16 that seemed heavier. Have sailed it twice in high wind and today in light wind and the boat had a creaking and groaning noise that I had never before experienced in over a decade of sailing Hobie's. As I inspected it, it is coming from the port hull. Again, kind of creaks and I got it to do it on land as I had it up on the beach wheels and leaned against the hull and pulled the shroud. The pylons seem tight and there are no cracks around the pylons and the seals are tight. Any opinion on the cause? Of course I wondered if the pylon was coming loose from within the hull, so I b-lined it back to the beach.
PostPosted: Fri Sep 04, 2009 5:19 pm
look at this thread...
viewtopic.php?f=14&t=13304
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
PostPosted: Sun Sep 06, 2009 10:31 am
Sailonsailor, If your gelcoat was to begin cracking around the pylons it won't be on the deck (usually), normally a crack will appear on the inboard side of the hull about 4 - 5 inches up from the bottom of the keel. The next issue of the HOTLINE will have an article on strengthening the pylon shoes and will have some photos of what to look for (cracks). If you want to see a couple of photos before the magazine comes out send me an email address to send them to. Mine is midwinterswest (at) cox (dot) net Rick
