It is currently Mon Aug 03, 2026 3:43 pm
PostPosted: Tue Nov 17, 2009 3:49 pm
hrtsailor wrote:
Is it possible that the length of halyard that comes over the pulley or pulleys is different?
Yes.
hrtsailor wrote:
The next question is, is there a difference in the halyards in the distance from the end to the slug?
Yes.
The Comptip mast has two small sheaves at the top with a distinctive square top to the mast, whereas the original masthead had one large sheave that gave the masthead a distinctive round shape.
The distance between the slug and the shackle on the Comptip halyard is several inches less than that on the original halyard.
The Comptip halyard is prone to fraying at the slug. My guess is that the original (Comptip) halyard on this boat broke at some point and was replaced with an original (all wire) halyard - the result is that even though the slug is set in the catch, the sail is not all the way up.
Those boats are from the 1988 Hobie 16 Nationals in Corpus Christi, TX.
PostPosted: Tue Nov 17, 2009 7:47 pm
MBounds wrote:
ET Hobie guy wrote:
Rojoyinc wrote:
REALLY PRETTY! but is the sail up all the way?
If you are asking about mine then all I can say is the sail is as far up as it will go. The sail WILL travel up slightly farther in the track, but there is no bead on the halyard to hook on to.The first bead is way too low, its on the second bead in the photo. I have actually wondered the same thing at times. Its possible I suppose the second bead on the halyard is too low for whatever reason. Maybe others can chime in.
Sounds like you have an old (all wire) halyard on a Comptip mast. The halyard for a Comptip is 95% rope, with only the last foot or so being wire.
I do not have a comptip mast.
'88 Nationals Blue
Hobie Alter Signature Model
Sail #11
Hobie Mirage Classic
PostPosted: Tue Nov 17, 2009 8:01 pm
Interesting, since the masts on those boats were originally Comptiped.
